Old 09-21-2019, 10:43 PM   #1
Big Blue
Big Blue's Avatar
Where does this go?
Can someone tell me where does this hose goes to. Look at the pictures, first one is a shot under the engine. The second one is a shot of the hose attached to the other end of "one ". DOES THIS GO TO THE CANISTER AND TO THE FUEL TANK?? Confused yet, I am.
Thanks john
Big Blue ( John )
79 Chevy Pick up.....My Dailey
STILL Working on a frame up: 1987 Truck body on a 78 Blazer frame. Need cab blasted to start project. Got the cab BLASTED, Now Prep and Paint. Started to lay SOME BONDO and primer. Done, Ordering paint. Got paint, Stuff painted,Cab,Fenders, Hood more later. 9/7/2015 Got the clear coat on,now time to take one off. Started to put things back (What a nightmare) like the heating and AC stuff,inside wire harness, outside AC unit and booster, still more. May 2016, still working on the inside. Got duck work in,heating and AC. Radio (stock) in dash with after market in console later, Speaker are hooked up, Steering column is in. Getting ready to drop the cab onto the frame, Working on engine now since I have the room. Well here it is 2018, got the engine in and it runs, now I need to get the exhaust system in so I can adjust the lifters, to loud right now. Got the exhaust on now I am waiting for the break parts to come in.
Big Blue is offline   Reply With Quote
Old 09-22-2019, 08:26 PM   #2
ray_mcavoy
Re: Where does this go?
I think that's part of the vent line for the front axle.
They usually have a section of rubber hose running up from the axle housing to the lower end of that steel line. Then another section of rubber hose running from the upper end of that steel line up to the back side of the radiator support. And the plastic vent cap on the upper end of the rubber hose located up alongside the radiator.
ray_mcavoy is offline   Reply With Quote
Old 09-22-2019, 08:56 PM   #3
Big Blue
Big Blue's Avatar
Thanks ray_mcavoy, That makes sense, I all ready have a hose coming from the front axle housing section. But maybe I placed it their by mistake and the hose that I all ready have hooked up goes to the tube in picture 1, and on the other end goes the breather thing. By George I think you got it, Thanks.
John
Big Blue ( John )
Old 09-22-2019, 09:08 PM   #4
sweetk30
sweetk30's Avatar
yep driver side by p/s pump is the 4wd front axle vent hose . the last end of the system should have the plastic vent thingy in the end of the hose .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
