Old 06-09-2004, 05:14 PM   #1
orange72350
orange72350's Avatar
Tremec tranny install
I was wondering who here knows what kinda work is innolved in installing a tremec? i have a turbo 350 that is slowly dying, and i dont want another auto. i was thinking about the tremec 5 or 6 speed. i know that i will need to find a spot to cut a hole for a shifter, build a crossmember of some sorts, and figure out a clutch of some sort. anyone have pics or the ability to point me in the right direction? thanx guyz
dale
2003 yamaha raptor. Stock, but it still hauls!!!!
2000 skiddo mxz 700. Camoplast 1.5 inch track, jaws twin pipes, b+b can, custom built and weighted clutch, wiseco piston, high comp heads. its very fast. wow.
72 c-10 longbox. Bright Orange. Brand new 350, rv cam, performer intake, qjet, headers, 2 1/2 inch exhaust into hooker areo chamber mufflers. Body work coming soon.
"dont let yer mind wander, its to little to go places by itself."
"Forget the herse, cause i'll never die"-ACDC Back In Black
"If It's To Loud, Yer Just Too Old"
"I Love Anything Fast Enough To Do Something Stupid In"
"Instant idiot, just add beer!!""
orange72350 is offline   Reply With Quote
Old 06-09-2004, 06:54 PM   #2
crazy longhorn
Fabricate till you "puke"
I did the richmond 6 in the longhorn, but did also look at the tremec tr3550, & the TKO. at any rate, you will need a good clutch setup(I highly reccomend the centerforce dual friction). my truck runs mechanical clutch linkage, with rod ends to smooth things out. the crossmember is custom built, but the trans bolted to the stock truck bell, took a 400 T yolk....& no driveline cut. here is a link to the tremec 5 spd... http://www.fortesparts.com/tremec.cfm Happy "rowin".....crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 06-09-2004, 09:24 PM   #3
Willy Prost
Here is the thread that I talked about the install in my 71 short bed stepside. I has a 250-6. The shifter issues might not be as critical if you have a V8 in the V8 position mounts.
http://67-72chevytrucks.com/vboard/s...d.php3?t=79258
Willy Prost is offline   Reply With Quote
Old 06-09-2004, 09:35 PM   #4
crazy longhorn
That last thread brings back something that i forgot to add.....my longhorn has a high hump pan, with about a 9" stretch to cover that Richmond. The shifter is right on the @ss end of the trans, & that sb is in I 6 position.....no fear tho, i have bucket seats crazyL
Old 06-10-2004, 12:32 AM   #5
gr8scott51
gr8scott51's Avatar
I put a T5 from an S10 behind my 350. The shifter is in the correct position. I had to put a spacer between the engine and tranny (the input shaft is long) and I made a driveline from the same S10. I used an 11" clutch from an Astro van.
I got this idea off the inliners.org site and read more about it on the Jags That Run (jtr.com) webpage.
Silence is golden, duct tape is silver. - Scott
gr8scott51 is offline   Reply With Quote
