Old 10-01-2019, 05:35 PM   #1
zac
zac's Avatar
Troubleshoot this electrical problem
Daily driver K20 in decent condition. Ignition switch start function was getting close to failure, so I installed a start button low on the dash as a backup until I could either get a new column with a key or replace the switch. I'd noticed here that getting into the column usual gets pretty involved. But it was just a precaution, switch was still working fine.
Truck had been sitting 5-6 days, started up fine, but I immediately noticed a weird humming or buzzing from behind the dash in the area of the heater control. Then the Fasten Seat Belt light came on bright. It hadn't done much but blink occasionally in years. Hit the throttle to kick it off high idle and the belt light got even brighter, so I looked at the voltmeter. Pegged all the way past 18 to the right. Electrical smell, moved the heater and blower controls around an heard a pop. But it could have been a coincidence. Shut the truck off, went to start it again and it was dead. Headlight, park lights tail lights all work. Nothing else, not even brake lights or hazards.
It was dark and not at my house so I had very little ability to check it out before my wife picked me up. And I won't be able to get back to it for a week. I'm figuring right now it is the alternator, ignition switch or something in the heater control. Obviously a fusible link is gone, not sure which one as I couldn't get a good look and haven't had much time to go over wiring diagrams yet. If you have any input please let me know.
zac is offline   Reply With Quote
Old 10-02-2019, 11:53 AM   #2
SunSoaked
SunSoaked's Avatar
Re: Troubleshoot this electrical problem
Replace the column, or Ignition switch, remove cheesy push- button switch and replace fusible link.
SunSoaked is offline   Reply With Quote
Old 10-02-2019, 01:10 PM   #3
hatzie
Moderator
hatzie's Avatar
The electrical portion of the ignition switch is on the outside of the steering column behind the knee panel.
If your ignition lock cylinder is borked it's a bit more involved to fix but not impossible. You will have to dig into the column to fix the lock cylinder.
18v + and super bright bulbs sounds like the regulator in your alternator took a dump.
You probably now have the honor of replacing any bulbs that were lit.
If the blower motor was on it may not be happy with you.
Basically anything that was switched on got some electrical stress if it didn't burn out.
There can be two fusible links at the starter and more on the J-stud... but this varies by year. The electrical diagrams will tell you what positions and how many.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 10-02-2019, 01:47 PM   #4
Dead Parrot
2nd on the alt going bad due to regulator. Disconnect before further start attempts.
Take an assortment of fuses. Possible one or more blew.
Take an assortment of bulbs for the same reason.
IIRC - there is a separate fuse for the blower motor on the firewall side for full speed blowing.
Original start problem: bad ignition switch, worn/broken tooth on either/or sector gear or rack piece inside the column.
Take a battery charger if you have one. You can use it to keep the battery up while you test things if replacing the alt isn't possible up front.
Dead Parrot is offline   Reply With Quote
Old 10-02-2019, 07:42 PM   #5
zac
zac's Avatar
Thanks. I was thinking regulator, but I’ve only heard.of them going the other way.
Maybe I’ll take the button out and go back to the screwdriver across the solenoid terminals technique.
Old 10-02-2019, 09:01 PM   #6
hatzie
Moderator
hatzie's Avatar
I've seen both. I'd much rather see em stop charging than have em run away. Lot less dangerous.
Old 10-09-2019, 02:10 PM   #7
zac
zac's Avatar
Finally time later this week. Looking at the diagrams, I see THERMO HW and fusible links. What’s the difference? It seems the power is coming up from the solenoid to the block, still getting to the lights but nothing to the ignition switch. I will probably bring an HEI module with me.
Old 10-09-2019, 02:15 PM   #8
hatzie
Moderator
hatzie's Avatar
Thermo HW are fusible links.
One of those tiny inconsistencies in the manuals.
Old 10-12-2019, 06:49 PM   #9
zac
zac's Avatar
So work schedule keeps getting changed, other stuff happens and I don't get to the truck until about noon today. Have all my tools and parts, trying to be optimistic. At this point the truck has been sitting in a hotel parking lot by the Cincinnati airport for more than two weeks. Parking spot right by the passenger side, I pull in and get out, notice right away the back of the seat is tilted forward. Not how I left it. Somebody came through the sliding window, over the toolbox in the bed, unlocked it and went through everything.
No worries, nothing of value in the cab, but then of course I notice the ignition cylinder had been destroyed. Some moron had actually tried to steal a 40 year old truck worth maybe $2000-$2500 tops. Sitting under lights in a parking lot, right next to a busy road by a couple bars and restaurants that have business until early in the morning. I know you guys in law enforcement see idiocy on a daily basis, but I was blown away. I assume the penalty for stealing a '79 K20 and a 2019 Duramax are the same.
The funny part is that had he gotten the cylinder to turn, the truck was still dead. Got it drug home, knocked out the rest of the cylinder so I could get the wheels to turn and drag it into the shop. So now I guess I will replacing the ignition cylinder or the whole column, or both. I know there are some good threads here on this stuff, if you know of any off the top of your head please point me that way. Thanks again for the help.
Old 10-12-2019, 09:41 PM   #10
dmack91
dmack91's Avatar
No computers,chipped keys, or PATS makes an older vehicle a much easier target for casual theives.
My column was hacked up when I got it. New\used $25 swap meet column was a simple swap. Much easier than rebuilding my original.
68 Chev C20- son has it now
83 K20 - bought from son
70 C20 - in progress
dmack91 is offline   Reply With Quote
Old 10-12-2019, 10:58 PM   #11
SunSoaked
SunSoaked's Avatar
Parking spot right by the passenger side, I pull in and get out, notice right away the back of the seat is tilted forward. Not how I left it. Somebody came through the sliding window, over the toolbox in the bed, unlocked it and went through everything...Sitting under lights in a parking lot, right next to a busy road by a couple bars and restaurants that have business until early in the morning.
The funny part is...?
Ya, who would've think? Stevie Wonder could have seen that coming. Squares are more valuable than you think.
Two days after buying my 85, I had a Viper alarm installed.
Old 10-17-2019, 08:31 PM   #12
zac
zac's Avatar
Replaced two fusible links, new alternator. Started and ran fine with my push button and a two handed screwdriver. Fuel gauge in and out. Tested the resistor and it seems fine, but it's been an issue since forever. Nothing seems burned out. I really didn't let it run long when it had the problem.
Took the column to a guy who redid it with new and used parts while I waited. Learned a lot watching somebody who knows what they are doing. Side note, the key cylinder that O'Reilly brought him didn't work. We had to take it back to the store and get one that actually turns. He installed and adjusted the new switch, but he made me take the old one home just in case. He wasn't impressed with the new one. Detents sloppy, etc. Guess what, it didn't work. Oh for two. I called the guy and he had me install the original, tweaking the adjustment so that it would fully engage the start function.
Burned wire on one of the ignition switch connectors. It's a small gauge brown and white wire that shares a terminal with a heavy orange wire. I traced it and can tell it's been an issue for a long time and doubt its related to the recent problem. The wire is a single silver conductor. Looped around the harness a bit and then went to the firewall connector. Looks like heat was an issue all the way. Couldn't get the firewall connector off because of course the screw that holds the halves together stripped out. I replaced the wire but would like to know what it does if anyone knows. It says on the diagram "omitted with 6 cyl gauges." My diagrams are incomplete screen shots and I can't really trace it. Anyone knows what it does?
Old 10-17-2019, 10:58 PM   #13
pitterpat
That's why I'm keeping mine looking sorry.
1984 Chevy Custom 20
$2500 work done on engine and transmission 2010/ less than 1000 miles on it since.
Here's my mild build thread,
http://67-72chevytrucks.com/vboard/s...d.php?t=783971
pitterpat is offline   Reply With Quote
Old 10-17-2019, 11:04 PM   #14
pitterpat
Don't know what year your truck is but it might be as easy to go to the junk yard, find a vehicle with a key in the ignition (what I did, TRUE) and take out the ignition cylinder from that veh. I had the cheesy push button on my 98 for about 5 years, found a YouTube video of how to remove the steering column...while doing the research I think that video showed how to remove the ignition lock...that was the problem with mine all the time, the ignition lock one of the pins was bad. duh!! Ignition wouldn't turn all the way.
Old 10-18-2019, 12:00 AM   #15
kipps
This thread explains that tan/white wire, circuit #130. Note that I misunderstood this wire in one of my posts. Read Ray_Mcovoy's post(#4) to get the correct info.
This thread has links to Hatzie's scanned manuals, including full wiring diagrams.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
Old 10-18-2019, 08:36 AM   #16
zac
zac's Avatar
Thanks for coming through here, kipps. I knew there was something different about that wire, which is why I wanted to know more. The fact that it’s a resistance wire makes sense given the heat issues it’s had. There was a place where a PO had taped up the burned insulation, but there were also areas I wondered if it had just happened. Makes sense since it was an alternator problem that started this whole dumpster fire.
Not sure if I will try a salvaged wire or the resistor. Probably the resistor.
Thanks again.
Old 10-18-2019, 09:02 AM   #17
hatzie
Moderator
hatzie's Avatar
The alternator exciter wire is the resistor on these trucks. The wire itself has a resistance somewhere around 47Ω. It's not a separate piece if the wiring hasn't been repaired or replaced. Resistance wire is used with the gauge package.
Folks that convert from warning lamps to gauges cut the 16ga exciter wire and solder in a 1/2W 47Ω or thereabouts resistor.
If the wire is crispy you may be having diode or regulator problems internal to the alternator.
http://67-72chevytrucks.com/vboard/s...d.php?t=743692
