Old 10-04-2019, 12:11 PM   #1
rudyyloverboiii
60 apache help needed
Hey guys and gals/
'picked up a new to me apache short bed stepper.
I cant seem to find any wiring diagrams specifically for this year and i know its not the same as my 64. i have a lot of burnt wires and PO had a lot of accessories hooked up to it any help is appreciated.
also the damn ignition lock cylinder is pretty complicated to remove without a key. any help? thanks! cheers!
rudyyloverboiii is offline   Reply With Quote
Old 10-04-2019, 01:10 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: 60 apache help needed
In the FAQ section https://67-72chevytrucks.com/vboard/...d.php?t=646002 of this 60-66 forum there are numerous thread links on wiring. For instance:
Electrical Threads:
60-66 Wiring diagrams from Hilandr451 http://www.6066chevytrucks.com/index.html
60-66 Chevy - GMC wiring basics
60-66 full body wiring : December 2009 / Electrical forum
62' chevy c10 wiring diagram needed : May 2014
see thread, PM one of the members there for a diagram
Wiring Diagram - Lights Only : May 2014
1960-1966 GMC headlight adjuster kit : July 2014
options for parts to use, if you cannot find original bits
Turn Signal Switch Question : June 2014
Indicator/park light bulb holders?? New ones available to but? : June 2014
Alternator numbers : March 2014
1966 c10 / OEM alternator parts numbers
John Lees Internal Regulator Alternator Conversion : October 2013
Any pics of trucks with spotlights????? : October 2013 /25+ posts
No Pop Out No Fail Front Turn Signals : October 2013
Headlight Switch : January 2014
pin out list of the headlight switch
No tail lights or brake lights : March 2013
A common issue on our trucks, is the brake/running lights not working due to a bad ground, especially after the truck is repainted. Read more about it, here!
64 Alternator/Wiring Problems.. Help.. Please.. November 2006
see post 8 for the Shorty Cox troubleshooting list
Alternator : November 2013
no brake lights? : February 2014
My brake light and dome light do not work : February 2014
information on troubleshooting...
One More Headlight Relay Thread
NOTE : The first post contains links to other headlight relay threads here in the forum.
Halogen Headlight with Relay's Upgrade : October 2013
headlight upgrades? : October 2012
Projector Headlights??? Is it possible? : February 2014
Unity Spotlight Repairs by markeb01
1960-1963 Spotlight Installation : May 2010 by markeb01
Simple Headlight Upgrades
Internal Regulated Alternator Wiring
is your blinker return not working? see this thread here
External to Internal Voltage Regulated Alternator Conversion
Ignition[switch] Bezel Tool : June 2013
Ignition switch issue : June 2014
questions about the types of ignition switches, year to year or other chevy switches that fit
1965 C10 - alternator or battery... : December 2009 / good troubleshooting tips for recharging system issue with external voltage regulator
Internally regulated 3-wire alternator conversion : March 2013
details in thread on how to wire, photos, links to tech, etc..
1965 chevy c10 truck - battery going dead at random times : February 2011 more excellent troubleshooting on electrical charging issues.
NEEDED: Flarestat 105 wiring diagram : November 2009 - [Electrical Forum]
has a link to site with a downloadable .PDF file with useful information.
Also see the specific Electrical forum for those hard to figure out things and to find great advice on all things electric related to trucks.
Old 10-04-2019, 03:32 PM   #3
rudyyloverboiii
thanks for ur help and i have gone through that before but majority of them are for 63-66. 60-62 havediffferent tail light wires. Im also not doing anything fancy like halogens. Was curious as to why i have green wires in the ignition loom which my 64 had no lime green wires
Old 10-04-2019, 06:04 PM   #4
LVPhotos
LVPhotos's Avatar
https://www.brotherstrucks.com/60-66...tinfo/LFA6066/
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 10-05-2019, 04:36 PM   #5
slepysal
slepysal's Avatar
There are two harnesses,do you need the wiring to the rear lights or the wiring from the cab?
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 10-16-2019, 07:46 PM   #6
rudyyloverboiii
i need both kinda ha.
I do know its 3 wires going to the back from the cab pink black and purple.
Which ones are the ones that supply the power from the cab?
I also forgot to mention its a step side and I got new lights from the truck shop out in orange and im lost in how im suppose to hook em up, do i need to splice them myself? thanks
