Old 06-09-2004, 11:11 PM   #1
sixty8chev
The Sauz
sixty8chev's Avatar
Question for the Lifted 2wd guys
I'm just wondering how big of lift coil i can go before i need different a-arms
I've heard 2" and I've heard 3" but not from anybody with experience.
And is it possible to get a camber adjustment block or something if i do decide to go with the 3"?
68 lwb 2wd (spread between 3 garages)
72 Burb - Flat Deck
92 Yukon 3" lift - 33's - the new bush pig
01 Sierra - Daily Driver (for now)
sixty8chev is offline   Reply With Quote
Old 06-10-2004, 12:18 PM   #2
Prerunner1982
Prerunner1982's Avatar
as with lowering, if you do extreme 2-3" it will cause ill effects, on tire wear and alignment. unfortunately nobody makes a lift spindle at this time for anything pre 88. you could make a cross member to lower the A-arms to counter act the longer coils and still provide lift. you could just add a body lift to avoid tire problems. i believe they make ball joint spacers to try and counter act the tires wear and alignment problems but i havent heard they are the miracle fix.. most still have problems. what size tires are you wanting to run, what are you wanting to do with this truck?
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 06-10-2004, 10:12 PM   #3
sixty8chev
The Sauz
sixty8chev's Avatar
I was hoping to get up to a 33x12.5 on there with maybe some minor trimming. I dont' do any serious off roadin with the truck its mostly just fire roads and camping trips. And at stock height I've never had my 31x10.5's rub so i don't think tire clearance will be a problem. I was just more concerned about gettin mileage out of a new set of tires.
And I did actually find some lift spindles for the 73-87's but they were on AIM's website so i dunno if I'd want to use them. I've heard mixed reviews about their products, and i think you need to go to atleast a 16" rim to clear them anyway.
72 Burb - Flat Deck
Old 06-10-2004, 11:37 PM   #4
Prerunner1982
i will have to check AIMs sight again, they had the 73-87s lift spindles previously but quit making them due to low demand. i have an 82 2wd with stock rear and just HD coils on the front. i run 32x11.50s right now, and have a slight rub on hard bumps, but if all you are wanting to run is 33"s i would say you will have to trim the front and rear of the front fenders and roll the top fender edge up quite a bit, and they should fit with no problem in the rear. i might have access to some 35"s that i might bolt on and just start trimming....
i assume you are looking to do this on your 68, so the fender clearances will more than likely be different, though i am sure 33"s should still fit in the back as my buddy had a 70 2wd with 33"s on the rear..
Old 06-14-2004, 03:45 PM   #5
sixty8chev
The Sauz
sixty8chev's Avatar
Looks like Aim doesn't have em anymore, called em today. I'm throwin a 78 front crossmember in the 68 that is why I came to ask you guys, and my rear end is already 3 inches higher, so if i do the axle over it'll be up 6 inches higher than the front, I like a rake, but thats just excessive. I'd really rather not do any trimming, so i guess i'm gonna have to throw the two inch coils in and wait to get everythign installed then take some measurements for the tires.
Thanks for the help anyway
72 Burb - Flat Deck
