10-07-2019, 04:02 AM | #1 |
327 distributer drive issue?
I have a something strange going on with the engine. I have just built a 327 circa 1967, for a truck, I have fitted a 350 oil pump, and drive.350 chevy distributer The intake manifold is an Edelbrock eps, for a 350 chevy. The oil pump drive shaft just touches the end of the distributer, and has not got enough length the locate into the hole to drive the oil pump? distributer is tight down on the manifold.
Is this something strange to the 327 as I have never encountered this before, I have read there is a chevy 2 oil pump, but the shaft is shorter? so it should be the same set up as I have,The distributer length is the same as the 283 and another 350 chevy I have, can anyone help
GMC K1500 1971 350 cu in th350 4wd Bondo Bob c 10 1971 stepside th 350 c10 1970 350 cu in manual air con stepside. |
10-07-2019, 06:39 AM | #2 |
Re: 327 distributer drive issue?
Hard to tell with out the parts out and checking the pump and the shaft to see what one is the problem. Did you put the oil pump shaft on the pump with the plastic retainer and install them as a assembly?
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
10-07-2019, 01:09 PM | #3 |
Moderator
Yes they discuss it here, post #16 may be your answer since your in that area of the world - https://www.jalopyjournal.com/forum/...o-short.30581/
10-07-2019, 02:11 PM | #4 |
Only 2 that i know 1 is 5.77" Meling IS55G long the other is 5.30" long IS55G (chevy 2 V8) maybe they gave you the short one?
1961 chevy K10 my build is------------61K10 build |
10-07-2019, 04:08 PM | #5 |
from what i have found out there are several more lengths the is55e is 5.96 inch which will be nearer what i need, i have the 1s55g which is 5.77 inch.
who would of thought there would be so many there is also a 6.25 inch shaft as well by morosso. many thanks for the links guys
10-08-2019, 03:04 PM | #6 |
the all steel ones are longer because of the coupler that goes over the pump shaft. no nylon coupler.
