10-07-2019, 09:19 AM | #1 |
60-63 Vintage Air
For the guys that have installed VA in a '60-63 (and maybe '64-66) how did you route the hose duct from the Evaporator unit over to the far drivers side?? Over the top of the steering column? Any pics would be helpful..
10-07-2019, 10:12 AM | #2 |
It's Better With Nitro
Re: 60-63 Vintage Air
While my engine choice is a little unique, this is how I routed my hoses:
http://67-72chevytrucks.com/vboard/s...&postcount=251 The evaporator kit calls for using the hardlines routed under the battery tray, but I wanted to route it to the outside of the battery tray area since I mounted my ignition unit and other components in that area.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
10-07-2019, 12:40 PM | #3 |
Vin,
Apologies if I wasn’t clear but I’m referring to the duct hose inside the cab. On the driver’s side specifically. Thanks for the response though.. |
10-07-2019, 04:32 PM | #4 |
The guys that installed mine route it up and over the column
10-07-2019, 11:03 PM | #5 |
Yep, up and over is what I did too
