Old 10-08-2019, 09:48 PM   #1
mtnbikerxt
WTB: Rear Frame Cut
The passenger side rear portion of the frame of my '70 C10 SWB 2WD was poorly repaired by the PO. I'm planning to repair it correctly this time. I'm looking for ~24" of frame behind the crossmember behind the rear axle. The crossmember is riveted to the frame about an inch or two forward of where the frame becomes horizontal after the rear axle hump.
For a SWB frame, I need everything behind the crossmember. If from a LWB frame, I only need ~24" of length starting at that crossmember. I found a picture online and marked up the portion I need (only need the passenger side).
If you have anything please let me know condition and the cost shipped to 06410. Thanks
-Gen
mtnbikerxt is offline   Reply With Quote
Old 10-09-2019, 07:19 PM   #2
casper71
Re: WTB: Rear Frame Cut
I have a 70 gmc c20 frame if your interested. It has leaf springs, not sure if rear part is different.
1972 3/4 ton 402/400
1971 k20 lwb 8.1.4l80.np205 w/37" tires and 6"lift
casper71 is offline   Reply With Quote
Old 10-09-2019, 10:43 PM   #3
Jeff's bowtie's
I have a long wheel base frame I can check condition of this area and post pics tomorrow
Jeff's bowtie's is offline   Reply With Quote
Old 10-09-2019, 11:08 PM   #4
mtnbikerxt
I'll do some research and try to figure out if they're the same or not. Thanks
Old 10-09-2019, 11:09 PM   #5
mtnbikerxt
Sounds good. Thanks
Old 10-10-2019, 09:09 AM   #6
LILREDGMC
Got a 1/2 ton previous from CO, and a 3/4 previously from NV. Let me know if the others don't pan out.
LILREDGMC
LILREDGMC is offline   Reply With Quote
Old 10-10-2019, 03:10 PM   #7
Jeff's bowtie's
Originally Posted by mtnbikerxt View Post
Sounds good. Thanks
No pits or rust it’s looks scaly in the pics but it’s just peeling undercoating $60.00 shipped plus PayPal thanks ......Jeff
Old 10-11-2019, 08:31 AM   #8
mtnbikerxt
Is this a 1/2 ton 2WD frame? From what I have read the 3/4 ton and 4x4 frames are slightly different. Thanks
Old 10-11-2019, 05:01 PM   #9
Jeff's bowtie's
This is a 1/2 ton 2wd frame
Old 10-12-2019, 12:29 AM   #10
mtnbikerxt
Works for me. What's your paypal?
