Old 10-14-2019, 09:12 PM   #1
2 Stovebolts
Square Body Military Wheels
Does anyone know anything about this type military wheels that were used on the square body K series pickup & blazer?
2 Stovebolts is offline   Reply With Quote
Old 10-14-2019, 09:32 PM   #2
72 tigger
72 tigger's Avatar
Re: Square Body Military Wheels
I bought a set off a diesel military blazer, they are 6 lug. I’ve never seen a 8 lug blazer
71 C10
72 K20
72 K10 Super
Kirk
72 tigger is offline   Reply With Quote
Old 10-14-2019, 09:37 PM   #3
2 Stovebolts
My bad - your correct regarding the Blazer - What's the deal with the outer ring? Is this a 2 piece wheel, where you can mount the tire by removing the outer ring?
Old 10-15-2019, 06:57 AM   #4
Isn't that the run-flat wheel that came on Humvees? I think they do unbolt to split the rim. The run-flat 'device' is a solid aluminum donut
Old 10-15-2019, 08:18 AM   #5
Jrainman
Jrainman's Avatar
[QUOTE=special-K;8609757]Isn't that the run-flat wheel that came on Humvees? I think they do unbolt to split the rim. The run-flat 'device' is a solid aluminum donut[/QUOTE
Agree Special K these look to be H1 rims, Double bead lock with run flats they came in 8 and 12 lug
Jrainman is offline   Reply With Quote
Old 10-15-2019, 10:16 AM   #6
MJN
MJN's Avatar
As stated above those are Humvee 16.5" wheels and not originally used on any square body GM trucks military or civilian. In order to run them, due to the backspacing, you'll need a dually Dana 60 front axle or some huge wheel spacers so they don't rub on the steering components.
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 10-15-2019, 10:27 AM   #7
2 Stovebolts
Somebody had them posted to fit GM....I was wondering....
Old 10-15-2019, 10:30 AM   #8
MJN
MJN's Avatar
Its the same 8x6.5 bolt pattern and will fit GM axles. But they did not come on GM trucks.
'17 GMC Yukon XL
VCCA member #58596
Old 10-15-2019, 11:50 AM   #9
2 Stovebolts
The posting listed 'cucv' - which I believe is military....thus my question....Didn't seem logical to me as, I never seen them on any military 'K' trucks....
Old 10-15-2019, 09:33 PM   #10
K5er4Life
They were all on humvee’s. That wheel is the older, original style 2 piece run flat. Later versions were a 12 bolt 2 piece wheel. The early model versions ran a magnesium inner run flat/beadlock while the later 12 bolt versions ran a rubber run flat/beadlock.
They are great wheels (if you want a 16.5”, and want to modify or off-road, tremendous load capacity). The backspacing on those wheels are quite a lot, somewhere around 8” if my memory serves right. Years ago people would re-center the wheel, companies would sell re-centering ring kits. That was a cheap and easy solution for those that wanted great off-road performance but didn’t want the beadlock wheel price.
I ran a set on my 1986 K30 crew cab with the 37” tires that came on the humvees. The truck was originally a dually. When I ran those wheels on the dually it was great bc I didn’t need to modify the axles or the wheels as the wider dually axles combined with the tremendous Humvee wheel backspacing allowed the tires to sit exactly perfect.
I would only run those wheels on a hardcore wheeler that never sees street, with the backspacing modified. Or run them on a dually but be prepared for the typically headlock issues such as tough to balance and leaky tires.
The setup was actually very impressive. One time I accidentally drove about 90 miles on a completely flat tire on the freeway but had no idea. I was riding dirt bikes one day and picked up a thorn while leaving the track in my truck. It leaked out all the air but couldn’t tell. By the time I got home the tire had a number of large gashes from running empty but that didn’t stop that big old truck from running 65 mph down the freeway the whole way.
K5er4Life is offline   Reply With Quote
