10-14-2019, 09:31 PM | #101 |
Always on the hunt...
Re: F/S OE 72 Big Block Parts, Brackets, Stove Pipe, Air Cleaner, Towers and/or Reque
Here are the last two BBC fan shroud pics, we also have a matching OE BBC short water pump 19" six blade clutch fan available if needed. This fan was removed from an original 72 C/20 402 big block truck, the clutch is in real nice shape and has the large w/p bolt pattern. $100. Mel
. Last edited by Classic Bowties; 10-16-2019 at 11:34 PM. |
10-15-2019, 12:27 PM | #102 |
On the road
Mel, I do appreciate your honesty. I am still interested in it, it would be residential address and zip is 71457. Please be patient with me if I don't answer right away as I am working overseas on an offshore installation and communications can be probematic plus I am probably 11 hours ahead of West coast time. Many thanks
Mike Castro- 72 SWB. Ochre and White. 496/400 turbo, GV OD ,Dakota Digital dash , tilt, Vintage Air, PS, hydro boost, factory buckets, console, QA-1 Coil over suspension, 20/20"Billet Specialties Magnetos 72 SWB. Med blue. 454/400 turbo, tach, tilt, Stock AC, PS,PDB, factory buckets, console, ECE 4/6 drop w/ 2" blocks and C-notch, 20/20"Coys- Crashed and destroyed by drunk driver Sept 2019. New 72 build in the works. My new build thread "Castro" https://67-72chevytrucks.com/vboard/...d.php?t=820934 My old build thread, the blue truck http://67-72chevytrucks.com/vboard/s...d.php?t=271489 www.louisianaclassictruckclub.com |
10-17-2019, 01:09 AM | #103 | |
10-17-2019, 10:44 PM | #104 |
On the road
Mel I will take it all, PM sent
10-18-2019, 12:02 AM | #105 |
I’m looking for the upper AC bracket, the one on the manifold. Any chance you have that one?
Thanks |
10-18-2019, 12:05 AM | #106 |
10-18-2019, 09:46 AM | #107 | |
10-18-2019, 12:13 PM | #108 |
I’ll take the middle one, please PM me your PP info, thanks.
10-18-2019, 12:39 PM | #109 |
10-18-2019, 12:58 PM | #110 |
Payment Sent, thanks Mel.
10-18-2019, 01:13 PM | #111 |
On the road
Payment sent, thanks, Mike
10-19-2019, 12:50 AM | #112 |
The BBC A/C intake manifold bracket (pictured center) has been shipped, your package went out via USPS priority on Fri. 10/18 and the expected delivery date is Mon. 10/21. Thanks again and let us know if we can help with anything else 67-72 related in the future, Mel
Hey Mike, funds received in full on the above pictured BBC shroud and clutch fan. Let me know when you are ready on your end for the shipment to be sent off, will get the package ready to go and we also still need an address confirmation. Thank you |
10-19-2019, 12:20 PM | #113 |
On the road
Thanks Mel
11-14-2019, 02:07 AM | #114 |
Hi Mike, hope your trip home was uneventful and went as planned. The big block fan shroud and clutch fan have been shipped out via FedEx home delivery on Wed. 11/13, as of this evening FedEx is projecting that you should see the box on Wed. 11/20 by the end of the day. Thanks again and let me know if we can help with anything else, Mel
01-10-2020, 12:26 AM | #115 |
hello i am looking for the ac bracket that bolts to intake manifold as well as piece that attaches to it, the metal line for distributor advance and the throttle stop and bracket that attaches to the front of carb with single spade terminal that points straight out. all parts are for 72 model thanks phillip
01-10-2020, 11:46 PM | #116 | |
01-13-2020, 02:24 PM | #117 |
just checking back thanks
01-13-2020, 02:52 PM | #118 |
Is any of the stuff in post still available???
01-14-2020, 04:45 PM | #119 |
Mel, sent you a PM about a carb spacer. Thanks.
01-14-2020, 06:21 PM | #120 |
If looking for BBC parts then yes, if you check first post you will see that the thread has been updated and multiples of these BBC parts have been added/sold over the last year plus. We decided to turn this one into a long running "request a BBC part" thread so that we don't have to have multiple threads for the same/like parts going at the same time and it also saves lots of room in our inbox storage as it cuts down on parts request pm's. Let me know which big block items you are looking for info on and we can add pics/pricing if parts are on hand. Thanks
Hello, just had a look back thru over two hundred messages and couldn't find anything from you on a carb spacer, if big block related just add requested parts info here and if we have it available I'll add it. Thanks, Mel |
01-14-2020, 06:51 PM | #121 | |
01-14-2020, 10:59 PM | #122 |
ill take them thank you
01-15-2020, 10:06 AM | #123 |
Mel, would you happen to have a carb spacer for the '68-69 396 engines with the "high rise" intake manifold? I believe the spacer for the earlier big block would've been shorter in height than '70-72. Also, how about the hard vacuum line for the earlier big block? My truck is a '68. Thanks.
01-17-2020, 12:45 AM | #124 |
Senoir Member
Thanks for all the great info & pictures listed here, they will help many of us with our BB projects. I've seen some pully numbers listed here for a 68 BB, but do you have the numbers for other years of 67-72? How about bracket numbers? Would be great to have a list of numbers for the brackets & pullies for SB & BB....never seen one. Thanks again!!
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4" 70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010 70 GMC Restoration Pictures http://67-72chevytrucks.com/gallery/...00&ppuser=4424 |
01-17-2020, 12:21 PM | #125 | |
OK, Do you still have the 68 air filter housing available, and would you have 68-396 exhaust manifolds, without the air injection holes??? THanks! |
