Parking Brake Front Cable Bracket
Guys I lost my original bracket for front parking brake cable. The one that holds the outer sheathing so the inner cable will slide only. It attaches to the parking brake assembly toward the firewall. Anybody know where I can find this part? Looks like all the new parking brake cables don't come with this...
1970 c10 longbed Here are pics of the cable installed, you can see the hole in the back where the original clip/bracket clamps to the cable to hold it. Here is another thread that has a picture of the bracket. http://67-72chevytrucks.com/vboard/s...d.php?t=766279
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444 "It's only money". ![]() Last edited by TA_C10; 10-21-2019 at 01:58 PM. |
![]() Join Date: Jul 2015
Re: Parking Brake Front Cable Bracket
It is essentially just a cable clamp, you should be able to find something that will work at your local hardware store. You want it to fit tightly around your sheathing. Something like this https://www.grainger.com/product/GRA...le-Clamp-6RNC3 or even a full one would work. I might have an old e brake assy. from a part out, I'll see if I still have an original that I don't need.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
