06-11-2004, 09:23 AM | #1 |
Any ideas? Truck not charging...
My battery was going dead so I figured since it was 5 years old I would replace it so I did, and the new one was going dead. So I thought my alternator wasn't charging so I had it tested and it is o.k. But when you start the truck and disconnect the positive cable from the battery the truck dies. Shouldn't the alternator keep it running once it is started? If the alternator is good what else could it be?
96 Bagged 2Door Tahoe 69 Blazer |
06-11-2004, 09:28 AM | #2 |
regulator regulates the charging of the battery that's why it's called a regulator
06-11-2004, 09:34 AM | #3 | |
Hmmmm...I thought that was built into the alternator? Or is it seperate?
06-11-2004, 09:35 AM | #4 |
there is a regulator on your rad support on the drivers side. You need that is you have an externally regulated alternator bud
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 Last edited by dubie; 06-11-2004 at 11:51 AM. |
06-11-2004, 09:47 AM | #5 |
67-72 Addict!
Is it internall or externally regulated?
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
06-11-2004, 09:51 AM | #6 | |
I ass-u-me..d it was internal but it might be external and this would explain everything. As soon as I get home I will check it. What should it look like? A sqaure box with at least 2 wires hooked up to it?
06-11-2004, 10:09 AM | #7 |
4 wires go into the external red- brown- blue- white
06-11-2004, 10:15 AM | #8 |
Thanks for the help. I need to get this back on the road.
06-11-2004, 10:22 AM | #9 |
Mike
The regulator is on the rad support on the drivers side.It has a 4wire plug on it.Take Your altenator to the parts store.Most will check it out for You at no cost,pep boys,autozone,advanced,ect..I just replaced mine,the regulator was fine.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
06-11-2004, 10:45 AM | #10 |
driverside rad support near horns
06-11-2004, 01:15 PM | #11 |
Never enough time!!
Internal regulated alternator has the side plug terminals in line(--) like that, External one has the terminals side by side(ll) like that. Good luck
06-11-2004, 01:53 PM | #12 |
what would happen if you hooked an internally regulated alternator up to the external regulator??
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
06-11-2004, 02:38 PM | #13 | |
Yep mine is external then, I have the side by side.
