Throttle sticks when using defrost
Not sure about this... PO put a new heater control in. I don't see where the throttle cable is binding. Seen this before? Quadrajet carb and an AC truck but compressor isn't hooked up.
1982 K10 SWB 1987 V20 - Sold - Doh! |
Re: Throttle sticks when using defrost
if your truck has a/c it has a idle compensator hooked up to the carb.so it comes on when changing over to defrost if your a/c works i would keep it on there. if not just unplug it its has green wire going to it
Found it. Fixed. I guess an AC compressor really chokes out these old trucks huh?
A carb does not have the luxury of adjusting on the fly.
Actually its still sticking after unplugging that compressor wire. The search continues
Might make sure the cable for the heat/cold flapper didn't get ran around the throttle cable under the dash when the PO replaced the heater control. Or a random wire bundle that moves just enough when the heat is on. IIRC every thing else is vacuum controls.
#7 | |
Alex. |
I must admit that when I first saw this thread, I thought about the "throttle stick" that I would wedge between the seat and the gas pedal to keep my old pickup running while it warmed up
Current/past Chevy/GMC trucks: 1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner |
That's funny. Axle had it right. I pulled that wire and it doesnt stick now. I assume if I had a belt on the compressor I would need to plug it back in to use defroster
