10-26-2019, 04:12 PM | #1 |
1971 Wiring Nightmare
Hello.
The wiring on this truck is completely screwed up. It was running when the engine was pulled, but I can’t figure out how it worked. The truck has an HEI, electric choke, and external regulated alternator. There is no plug for the alternator coming out of the harness...crazy. The black insulated wire is green. I turned the key on, but have no voltage to any of the wires. I’m not good with wiring and don’t want to screw this up anymore than it is. How do you think it goes? Posted via Mobile Device Last edited by Perma71; 10-26-2019 at 04:22 PM. |
10-26-2019, 05:26 PM | #2 |
Re: 1971 Wiring Nightmare
If your truck ran before the engine removal, something happened at that time that created your problem.. No disrespect meant but posting a picture of a wad of wires isn't much for us to go on..
This site has an electrical forum. One of the sticky threads in that forum is a posting of downloadable wiring diagrams.. Go there, and download the wiring diagram for your truck.. Trace out and locate the flow of electrons path".. You can then post questions requesting more specific information. As for electric chokes, upgrading to internal regulated alternators, HEI installations, those subjects have been covered in several threads.. Use the site's search feature for that information.. This site is a great place for help with the problems on these old trucks.. You just have to be more specific with "what ails your truck"... |
10-26-2019, 06:20 PM | #3 | |
I didn’t take the wiring apart. I just put the engine and trans back in. All the plugs are gone and have been replaced with spade connectors. Posted via Mobile Device |
10-26-2019, 06:44 PM | #4 | |
Green is a color used in engine function monitoring, and among other functions, it's also used in lighting circuits.. The wiring diagram will aid you in determining exactly what your specific wire does... As I previously stated, I can't tell from your single picture, but just looking at your picture, I don't believe the HEI installation/modification was properly done to the wiring.. |
10-26-2019, 06:49 PM | #5 |
If the green wire (Light green) has a woven black tar like sleeve covering it most likely the wire for the temperature switch or sender if you have guages. See photo but ignore the yellow wire coming out of the sleeve as that goes to my electric choke which wasn't installed when the photo was snapped.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
10-26-2019, 07:07 PM | #6 | |
10-26-2019, 07:13 PM | #7 | |
10-26-2019, 07:27 PM | #8 | |
The "yellow to the coil" all the way back to the starter solenoid should have been completely removed as part of the HEI installation.. There are one or two correct ways to supply power to an HEI unit.. There are numerous, numerous ways to do it wrong.. Some will work, most won't.. |
10-26-2019, 07:42 PM | #9 | |
Thank you for the help. I’ll do the HEI wiring ASAP. The whole harness needs to be replaced though. It’s literally in tatters. Posted via Mobile Device |
10-26-2019, 08:16 PM | #10 | |
Seriously, you'll need wiring diagrams close at hand when you do any electrical work.. With all the years of experience I have, I still often refer to wiring diagrams.. They are an immense aid.. If your under hood wiring is hacked and spliced beyond suitable repair, your best bet is to purchase an exact year specific harness.. You'll still need to make modifications, add circuits, etc to "mate up" with the mechanical modifications already made to your truck.. You'll need those diagrams to aid in that process.. FYI, I bought the truck currently in my avator (sp) about 2 years ago.. It originally was an I6 w/tott.. It now has a 454 w/ automatic.. The under hood wiring was a mess.. Full of wire nuts, unfused runs, and mostly a scary fire inviting mess. I built a new harness accurately reproducing the colors, junctions, connectors, everything as if it came from the factory.. I incorporated the necessary modifications for charging system and HEI.. Works perfectly and cost me less than $50 for the wire, terminals, plugs and connectors... Hang around here long enough and you can probably do the same... |
