Old 10-29-2019, 10:20 AM   #1
8man
Serpentine belt systems
I don't have a lot of room between the radiator and the crank in the 48 on the S10 frame, and I need some of that room for the electric fan.
There are a lot of serpentine belt systems out there, and I was looking at one when I saw it was 8" from the front of the pulleys to the tip of the crank! That won't work for my truck.
So does anyone have a recommendation for what they used that took up minimal room, maybe 4"?
If you have done this set up, how much room did you have between the back of the radiator and the end of the crank? Maybe I need to start over and move the motor back some.
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 10-29-2019, 11:44 AM   #2
flyingdet444
Re: Serpentine belt systems
I used a system off of a V6 1989-90 Firebird. My passenger side valve cover is 1 inch from the firewall. The electric fan motor just barely misses the fan pulley bolts, but it all works. Good luck.
flyingdet444 is offline   Reply With Quote
Old 10-29-2019, 12:52 PM   #3
mr48chev
mr48chev's Avatar
A lot of guys like the setup off a 4.3 V6. Same front end of the engine as a small block that has all the bolt holes for brackets.
That is one thought though, as you have to make sure what ever you get you get a setup that is compatible with your engine. They "they are all the same" doesn't apply when trying to bolt pieces for a mid 80's 350 on a mid 60's 327.
My ongoing truck projects:
Old 10-29-2019, 12:55 PM   #4
8man
Thanks Joe. I may have to scrap the 283 as I don't know the year. It looks in pretty good shape inside - I took it apart again, but not knowing the year makes getting anything to fit it problematic.
8man-aka Robert
Old 10-29-2019, 01:13 PM   #5
mobileortho
mobileortho's Avatar
I don't have an S-10 frame, but used the brackets from the 88-92 Camaro/Firebird. Even with the stock frame it was a little tight. I had to cut off a couple of pieces the plastic guard to clear the fan pulley.
Robert C.
1950 3600
3600 re-do, shortening it up
If it's true what they say, "You learn from your mistakes,"
I'm a Genius in the making.
mobileortho is offline   Reply With Quote
Old 10-29-2019, 02:48 PM   #6
NorCalGal
NorCalGal's Avatar
Robert I used the gm serpentine front drive on mine and my fan barely fits.
Jan's 53
NorCalGal is offline   Reply With Quote
Old 10-29-2019, 03:35 PM   #7
8man
Thanks.
Jan, I'll take "barely" it's "uh oh" that worries me. I was looking at a serpentine kit until I read it was 8" from the tip of the crank to the outside edge of the kit. I do not have that much room without the fan.
8man-aka Robert
Old 10-29-2019, 03:40 PM   #8
Driver_WT
Driver_WT's Avatar
I have SBC 350 with serpentine set up from S10 4.3 V6. This is on an S10 chassis. Still in construction mode, but looks like it will all fit. Long water pump for SBC is about 7" out from the front of the engine block at the pulley end, so the pulleys on the serpentine system will be around 7 to 8.5" from the front of the block.
Wade
53 Chevy 3100, SBC 355, 700R4, S10 frame, Ford 8.8 rear with 4.11 gears, front disc & rear drum brakes
Driver_WT is offline   Reply With Quote
Old 10-29-2019, 05:00 PM   #9
mick53
I'm not a V8 guy but my crank was made for SBC damper. The spacers are in there for crank trigger. The outside of the pulley is about 2" from the crank snout. I'm having a SFI damper made with serpentine pulley on it. Then crank trigger 3/8", 3" blower pulley and dry sump oil pump pulley 1". It's still only about 5.5" in front of crank snout. I have electric P/S and A/C.
mick53 is offline   Reply With Quote
Old 10-29-2019, 08:01 PM   #10
Matt_50
Mick53 I'm a little jealous of that engine.
8man do you have the accessory holes drilled in your heads?
1950 Build
Matt_50 is offline   Reply With Quote
Old 10-29-2019, 08:11 PM   #11
Matt_50
Read this.
http://67-72chevytrucks.com/vboard/s...d.php?t=643815
1950 Build
Old 10-29-2019, 08:13 PM   #12
Matt_50
And see post 12 I think on this one. I've had these saved. Keeping an eye out for one too.
http://67-72chevytrucks.com/vboard/s...d.php?t=233335
1950 Build
Old 10-29-2019, 09:11 PM   #13
mick53
Wait till you see my 12 port cross flow aluminum head. The one on there is a race head I had made before I knew I could get the other one. It's the first of it's kind from New Zealand. About 10 years in R&D. Thanks.
Old 10-30-2019, 08:54 AM   #14
8man
Thanks Matt. Yes the heads do have some holes, but one of the articles you sent me has a reference guide to determine year by hole pattern. I tried searching several different ways, and I didn't find either of those articles. My search function skills are worse than my welding!
8man-aka Robert
Old 11-07-2019, 09:19 AM   #15
gigamanx
Check my build thread. I went through similar issues with finding a serpentine systems. I'm pretty sure I just went with a 1995ish and cobbled the parts from craigslist. Didn't end up being terribly expensive just make sure the pulley system is from the same vehicle. There are a few configurations. I probably have half an inch between the electric fan and the water pump pulley
An example...
https://www.ebay.com/itm/SERPENTINE-...Condition=3000
Wasn't in my build thread
Try this thread when I was pi$$ed off at my accessory drive...
http://67-72chevytrucks.com/vboard/s...d.php?t=747312
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist
Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition!
Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride
gigamanx is offline   Reply With Quote
Old 11-07-2019, 09:23 AM   #16
8man
Thanks Gigamanx. That helps.
8man-aka Robert
Old 04-12-2020, 04:08 PM   #17
FatherandSon
8man, How did you solve your accessory drive system space issue? I'm at same point. I installed a GM performance system but it left me short of room for the fan and barely enough for the radiator.
FatherandSon is offline   Reply With Quote
Old 04-12-2020, 04:14 PM   #18
8man
I went with the KWIK performance system. It uses the Sanden mini compressor and mounts very close to the crank. Just enough room after I had the inlet on the bottom of the radiator turned down on a 45.
8man-aka Robert
Old 04-12-2020, 04:41 PM   #19
FatherandSon
Thanks! Do you know the distance from block face? Can you send me a product link?
Old 04-12-2020, 04:44 PM   #20
FatherandSon
is that a short reverse rotation water pump sytem?
Old 04-12-2020, 04:44 PM   #21
8man
http://www.kwikperf.com/
Here is the link. Yes on the water pump. I'll have to go measure from the block to the radiator.
8man-aka Robert
Old 04-12-2020, 04:49 PM   #22
8man
If you unbolt the water pump, and measure from the face of the block where the bolt hole is to the radiator, it's 9.5".
Does that help?
8man-aka Robert
Old 04-12-2020, 05:00 PM   #23
FatherandSon
Yes. Thanks for your trouble and the info! How much clearance did you end up with in the end between you drive system and fan?
Old 04-12-2020, 05:02 PM   #24
8man
1/2" or so, maybe a little more. I've held the fan up, but not mounted it yet and so I don't have a really accurate measurement, but it's enough to clear.
8man-aka Robert
Old 04-12-2020, 05:05 PM   #25
FatherandSon
Great! I was afraid I would have to go with a push fan. Thanks again for your help! The one upside to all that's going on is I have time to work on my truck. Stay safe!
