Old 10-28-2019, 07:35 PM   #301
350TacoZilla
Re: 1965 LWB Stepside Build
Looking good man, keep up the good work and that thing will be done in no time.
I remember years ago seeing a truck with the plug wires under the manifolds on a rams horn setup like yours. I think he made a bracket that bolted to the back of the heads that the wires were secured to with the universal clamp style hold downs.
350TacoZilla is offline   Reply With Quote
Old 10-28-2019, 09:23 PM   #302
cwcarpenter98
cwcarpenter98's Avatar
Here's how I ran my plug wires. Stock ram horns, but same idea.
I use factory replacement plug wires for a 77 corvette. Still works with the stock ramhorns, but 8mm for the HEI dizzy
Your's is looking great!
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 350, Saginaw 4 speed
Old 10-30-2019, 12:00 AM   #303
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Originally Posted by roll_the_dice View Post
Finished running the fuel lines to the FiTech. I have an in tank fuel pump, so I had to run the return line back to the tank. I need to torque the fittings on the fuel filter tomorrow. The picture reminded me I didn't torque them! I also need get the clamps to clamp the lines to the frame rail. The zip ties are just temporary.
I also sat the batwing air cleaner on just to see what it was going to look like. It looks better than I imagined. I love the old school look!
My install is far from clean.
I just used the stock throttle linkage.
Hasn't given me an issue.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 10-30-2019, 12:07 AM   #304
roll_the_dice
roll_the_dice's Avatar
Thank you sir!
roll_the_dice is offline   Reply With Quote
Old 10-30-2019, 12:22 AM   #305
roll_the_dice
Thanks Christian...appreciate the pictures. I did a little research and I may go with 135 degree or straight plug boots instead of the 90's..like this.
Old 11-01-2019, 10:13 AM   #306
roll_the_dice
Finally ordered my shifter a few weeks ago. It was "delivered" last Friday, but I never received it. I thought someone had stolen it from my front porch (which happened last year with some packages). I called Fedex and the shipper, but I didn't think much would happen because it was "delivered". This morning on my front porch was a box...My Lokar 16" shifter arrived one week later...I assume it was delivered to a wrong address and the person finally brought it over? Not sure why it took a week, but at least I have it!
I have had this vintage Indian Motorcycle shift knob for years waiting to install in the truck. So I tried the knob on the shifter...perfect thread match. I had done research on the threads and that is one of the main reason I chose the Lokar shifter...it matched perfectly without an adapter.
I didn't even get the entire shifter out of the package before I snapped a picture! I think it is going to look even better installed!
Old 11-06-2019, 09:04 PM   #307
roll_the_dice
Got my power steering lines connected this week. Going to try and fire up the engine for the first time this weekend! Should be an awesome weekend.
Old 11-07-2019, 05:28 PM   #308
RDrancher
RDrancher's Avatar
Following along on a great build. And thanks for the trans crossmember link.
Romans 10:9 - The Truth
RDrancher is offline   Reply With Quote
Old 11-07-2019, 07:22 PM   #309
roll_the_dice
Thanks, I appreciate you following along. You are welcome on the trans crossmember. I really like it...and think it was reasonably priced and was plug and play. I also had tons of questions for them before I bought and they answered them all!
Old 11-19-2019, 04:47 PM   #310
roll_the_dice
Trying to get the engine started...got it started once, but can't get it again. Trying to diagnose/figure out the FiTech EFI is a lot of information. Once I can get it started and can start it easily, I will start putting it back together...hope to be driving it before the enf of the year.
Old 11-19-2019, 10:03 PM   #311
350TacoZilla
I'm sure you'll figure it out man but 2 things I commonly check over are make sure you have plenty of ground wires (motor to frame,motor to cab etc) and check fuel pressure as close to the injection unit as possible. I had a friend chasing problem for week or more only to find out he had a block in a fitting after the gauge.
Old 11-20-2019, 12:33 AM   #312
Captainfab
60-66 Nut
Hopefully you haven't hurt the cam and lifters.
Old 11-21-2019, 09:34 PM   #313
roll_the_dice
Thanks...I bought and added new grounds and battery cables...so I have that. I checked fuel pressure and it is good. I have been doing a tone of research and reading...I think I about have it figured out. I think it is in the cranking fuel settings...
Old 11-23-2019, 01:55 PM   #314
roll_the_dice
Got the engine started today! Was not getting enough air...I still need to adjust that, but got it going. So excited.
Old 11-24-2019, 12:58 AM   #315
Captainfab
60-66 Nut
Were you able to immediately run the cam break in?
Old 11-24-2019, 01:06 AM   #316
roll_the_dice
When I bought the engine, I paid extra to have that done. They offered it as a service. So no worries. Was worth it to me to have it done.
Old 04-19-2020, 09:52 AM   #317
roll_the_dice
Finally got back to the truck ...installed the Brake booster bracket, booster, and MC. We are supposed to get more storms today, but if not, will try to get on the hydraulic clutch MC and connect to the clutch pedal.
Old 04-19-2020, 12:46 PM   #318
cwcarpenter98
Looking good! I was missing seeing updates on your truck. Glad to see that you've been putting some work in on it
Christian Carpenter
Old 04-19-2020, 12:51 PM   #319
roll_the_dice
Thanks Christian...good to be back. I got the proportioning valve installed before online Church this morning...now it is raining, so at least I got something done today.
Old 04-19-2020, 02:39 PM   #320
roll_the_dice
I also forgot...right before all this started happening I got my seat recovered. It has been ready for a few weeks, but it is in SC and I haven't been able to go pick it up yet. Hopefully soon. I love the seat...will get better pictured when I actually get it...but it has a hint of green in the perforations of the seat. The person who did it also sandblasted the frame and painted it black before putting new foam on and making sure the slide feature worked as it should as well.
Old 04-20-2020, 01:24 PM   #321
straight6chevyguy
straight6chevyguy's Avatar
Good to see ya back and at it!
I like the seat.
1965 Chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601
1976 Chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037
1978 Chevy c20 350 4speed
1998 Chevy c1500 4.3L 5speed
1999 Chevy k1500 Suburban 5.7L auto 4x4
2002 Chevy s10 4.3L auto 4x4
1971 Mercury Monterey wagon 400 auto
Plus other misc. ... To many projects!
straight6chevyguy is offline   Reply With Quote
Old 04-29-2020, 10:17 AM   #322
roll_the_dice
I like the seat.
Thank you sir! I picked up the seat Saturday, but it is still in the back of my SUV being "quarantined" haha I am waiting on some new seat bolts then will get it in later today or tomorrow. Pictures don't do the seat justice. I will post more when I get it out of the SUV.
Old 04-29-2020, 10:22 AM   #323
roll_the_dice
Finally getting around to the master cylinder for the hydraulic clutch. I decided to paint the MC to make it pretty...just don't want it to rust. I also finally made my throttle linkage. I have had the parts for a while, but got it finished. I used a 5/16" brake line to cover the threaded rod....might as well paint it right? I think they both look good.
I need a second pair of hands to help me install the MC...but will get it done this week.
Slowly getting it put back together...one thing at a time.
Old 04-29-2020, 02:39 PM   #324
roll_the_dice
Got the clutch connected the brake MC...next is the brake pedal to the booster...then all 3 pedals will be connected...YAY!
Here are some random pics of the finished install and a better pic of the throttle linkage.
Old 04-30-2020, 03:54 PM   #325
cwcarpenter98
I like the painted clutch MC. Also, nice trick with the brake line over the threaded rod. It definitely makes it look cleaner
Christian Carpenter
