Old 10-31-2019, 12:10 AM   #1
ironadict
ironadict's Avatar
Windshield help please!!!!
So I got all new glass for my truck from auto classic city. New gaskets and trim molding as well. Had a buddy who’s roped in lots of windshields in a shop he worked at come by and help me. We worked on this damn thing for hours and can not for the life of us get it seated all the way. The bottom corners aren’t going all the way into corner and it seems like the top corners aren’t pushing all the way back to the pinch weld. My hands feel shattered from slapping this thing and I even resorted throwing elbows but we just can’t get it in there.
Is there something we’re not doing right? We used foaming window cleaner liberally to lubricate. He also put on some setting compound from a caulking gun that’s supposed to help it seal. We started by setting the bottom down then roping it around one side work that side in. Then moving to other side and working that side in. He also wanted to wait to put on trim molding until it was in. Is that correct? Any advice would be much appreciated. Unfortunately no local glass shops will do old schools any more.
HOTROD HOODLUM
ironadict is offline   Reply With Quote
Old 10-31-2019, 01:39 AM   #2
mongocanfly
mongocanfly's Avatar
Re: Windshield help please!!!!
I've heard folks having lots of issues with reproduction glass not being the same as original...could be the glass...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 10-31-2019, 02:09 AM   #3
MiraclePieCo
MiraclePieCo's Avatar
How supple is the gasket you got? On mine getting a softer gasket made all the difference.
1951 Chevy Panel Truck
MiraclePieCo is offline   Reply With Quote
Old 10-31-2019, 07:51 AM   #4
ironadict
ironadict's Avatar
Ok. Yeah I think we are going to pull it out and lay it in the old glass and see how the contours match up. Then we will also put the windshield into the truck with no gasket to make sure it fits. If all that is good we we’ll heat up the gasket a little and hopefully that will make it easier.
HOTROD HOODLUM
Old 10-31-2019, 08:21 AM   #5
ironadict
ironadict's Avatar
Thanks for the advice. Do you know who makes the softer gaskets?
HOTROD HOODLUM
Old 10-31-2019, 07:44 PM   #6
sack54
Just put one in my 1956 GMC . Its a bear I was using glass from 56 , got the whole windshield in except top left ,one slap it went in and cracked. Got new windshield and Steele gasket .Took like 10 mins. in and done. Lots of soap and plam slaps and we tugged with windshield handlers ( suction cups) to get even not to hard to rope in
sack54 is offline   Reply With Quote
Old 10-31-2019, 09:15 PM   #7
ironadict
ironadict's Avatar
Man I’m so jealous. Yeah I have a feeling it’s the gasket. I dry fitted the glass and it seems like it should be a perfect fit. Did you put it in with the stainless steel molding or just the rubber?
HOTROD HOODLUM
Old 10-31-2019, 10:07 PM   #8
roger55
roger55's Avatar
Did you set your windshield in place without the gasket to establish a center and then mark both the glass and the body? Without doing that first it would be very hard to find the exact center when doing the final install with the gasket around the glass.
That's what I did and and it worked perfectly first time.
roger55 is offline   Reply With Quote
Old 11-01-2019, 12:40 AM   #9
DransportGarage
DransportGarage's Avatar
Originally Posted by miraclepieco View Post
how supple is the gasket you got? On mine getting a softer gasket made all the difference.
x2.
Bob
"It won't take long and it won't cost much."
'55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed)
Bob's Retirement Build - My 55 TF
Bob's 700R4 Build (how-to)
DransportGarage is offline   Reply With Quote
Old 11-01-2019, 06:09 AM   #10
MiraclePieCo
Steele Rubber.
Old 11-01-2019, 08:45 AM   #11
bowt1ed
Roger, where did you source your glass?
Jim
bowt1ed is offline   Reply With Quote
Old 11-01-2019, 09:17 AM   #12
roger55
roger55's Avatar
I got my glass from a local store named Angelo Auto Glass. I've bought several windshields from them to install myself for various cars. Took 2 days for him to get it in. He inspects thoroughly before even calling me that it's ready. One time he sent one back and got another because he saw something he didn't like.
He gives me a price that is only a little more than what I can get from the suppliers over the internet but he doesn't charge me any shipping at all so it ends up cheaper.
I did get the rubber from Brothers and I don't know what brand they supply but I had no complaints whatsoever with it.
Old 11-01-2019, 09:49 AM   #13
bowt1ed
Old 11-01-2019, 12:21 PM   #14
_Ogre
_Ogre's Avatar
i'd be curious to see the match between the 2 windshields too
fyi... i used rubber from brothers
also how well do your doors fit to the cab?
shop air compressor timer
Old 11-01-2019, 07:02 PM   #15
mgchevyparts
mgchevyparts's Avatar
Seriously doubt it's the glass. I bet it's the gasket. Did they send you Precision brand? Those are terrible.
1957 CHEVY 1/2 TON SHORT BED
1940 FORD 1/2 TON SHORT BED
mgchevyparts is offline   Reply With Quote
Old 11-01-2019, 07:56 PM   #16
dsraven
test fit glass to opening
use new soft rubber
test fit new rubber, mark center
lube new rubber with dish soap or tire mounting slime around the outside lips, something that will come of with water and not damage paint
center windshield without rubber and use tape or grease pencil to mark the body and tape to mark the center of the glass and the center of the body
install the rubber on the glass
install a cord/rope in the lips of the rubber, around the outside of the rubber, so the ends overlap at the bottom of the glass
lay the glass/rubber/cord into the opening, have help.
have helper press firmly, but not point pressure hard enough to crack the glass, so the lips of the rubber can be "started" over the metal lip on the cab opening
once the lips are over the steel, have helper(s) firmly apply pressure while you pull the cord from both ends. slowly. the cord should pull the lips fully over the steel cab lip as the cord is pulled around the glass and comes out of the rubber. be careful with the pressure from the outside because too much will crack the glass, especially when the glass gets started into the curved area.
watch the video below, maybe help you.
https://www.hotrod.com/articles/how-...nd-rear-glass/
Old 11-03-2019, 04:17 PM   #17
lynx5653
lynx5653's Avatar
Just a thought if you have the deluxe trim for your windshield it has to go in gasket before you install glass, don't know if this will help with fitment
1955 2nd on 86 chassis
Daily driver
lynx5653 is offline   Reply With Quote
Old 11-04-2019, 03:42 PM   #18
FAKKY
Slight derail.
Never had to do this.
Where is the best video that shows the process in detail on youtube ?
FAKKY 57 PANEL BUILD
FAKKY is offline   Reply With Quote
Old 11-04-2019, 04:31 PM   #19
akdg87
akdg87's Avatar
Had a similar issue with my 55; had a buddy come over and we tried tag teaming it for 2 and a half hours. No Dice.
Tried again the next night by myself and i had it in within 15 minutes, no idea what i did differently but it literally fell right in.
i used the spray-away foaming glass cleaner, seemed to work the best and when it drys it doesnt appear to leave any residue or lubrication.
build thread
1955 cameo turbo lsx
1993 K1500 Blazer 5.3/4L80e
2009 CTSV Sedan
akdg87 is offline   Reply With Quote
Old 11-05-2019, 06:31 PM   #20
ironadict
ironadict's Avatar
I believe brothers sells precision. I just bought the rear gasket for my truck from them and that’s what they sent.
HOTROD HOODLUM
Old 11-05-2019, 06:32 PM   #21
ironadict
ironadict's Avatar
Originally Posted by FAKKY View Post
Slight derail.
I found a few for our trucks but they were all standard cab gaskets as in no stainless trim.
HOTROD HOODLUM
Old 11-05-2019, 06:35 PM   #22
ironadict
ironadict's Avatar
Yeah I dry fitted the glass and it looks good. The gasket they sent me is gold star brand or something. Pretty cheap so I took everyone’s advice here and ordered a Steele rubber gasket. Unfortunately though that has my truck down for at least another week waiting on that.
HOTROD HOODLUM
Old 11-05-2019, 06:36 PM   #23
FAKKY
Thats ok .... just kinda of curious if I ever had to do it what the best process is.
Figured there was a video somwhere.
Interesting on the gasket making that much of a difference.
Old 11-06-2019, 10:17 PM   #24
_Ogre
_Ogre's Avatar
lynx5653 is correct. trim goes in before installing the windshield
i did the windshield on my 63 chevyII with the trim
Old 11-16-2019, 09:05 AM   #25
captn6
Just a bit had a guy put my 59 windsheild in 2 things he said to look for one repo glass sometimes are not to size said a little difference and it will not fit right .two he hates the stainless trim rubber alot harder to get it right good luck. I did get my glass from LMC had no problems
captn6 is offline   Reply With Quote
