Old 03-14-2017, 12:01 PM   #1
abohler1
abohler1's Avatar
MRC Hydroshox Opinions
Has anyone else seen the release of Mittler Bros Hydroshox? I have been waiting for a race inspired suspension design to run on big wheel frame laying trucks for years. I believe it has finally arrived.
I have never dealt with hydraulic parts, but have been using air suspension setups for years. Anyone else excited? Any concerns with someone running hydraulic fluid?
https://www.youtube.com/watch?v=bg7sCC_fF7Q
abohler1 is offline   Reply With Quote
Old 10-18-2017, 12:53 PM   #2
abohler1
abohler1's Avatar
Re: MRC Hydroshox Opinions
Diesel brothers put out a truck on hydroshox on TV. Looks very promising. Anyone else happen to see the show?
Old 10-18-2017, 02:41 PM   #3
mongocanfly
mongocanfly's Avatar
I saw part2 of that build but it didn't go into a lot of detail..it may have had more in part1...it looks expensive from what I saw
Old 10-19-2017, 10:22 AM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I've had plenty of hydraulic experience, but in terms of lowriders, they are far from what I'd call a performance suspension. I've never seen these particular units in use, so maybe they built a better mouse trap?
Usually the issue with hydraulics is weight, leaks, and ultra high pressure. Its much easier to clean up a damaged air line than it is to clean up 5 gallons of jack oil.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 10-24-2017, 10:25 AM   #5
SCOTI
SCOTI's Avatar
The technology is leap years ahead of 'traditional' hydraulic set-ups but I bet it comes @ a price.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-12-2018, 12:30 PM   #6
abohler1
abohler1's Avatar
I've decided to make the leap. MRC is doing the front clip and nsane hotrodz doing the rest of the chassis. Will probably take some time since it will be an expensive project, but will keep everyone up to date.
front clip $5k all in
hydroshox $5k complete kit
Old 04-12-2018, 05:15 PM   #7
Sik66
Finnegans garage on YouTube.....fitted his c10 with it....looks like cool setup,basically mini coil overs on hydraulic Rams .....accumulators being the shock absorbent...
Sik66 is offline   Reply With Quote
Old 06-12-2018, 09:53 AM   #8
abohler1
abohler1's Avatar
Step 1 in progress
Old 01-16-2019, 02:59 PM   #9
abohler1
abohler1's Avatar
Getting there slowly but surely
Old 01-16-2019, 03:01 PM   #10
abohler1
abohler1's Avatar
And a few more steps down
Old 01-17-2019, 12:38 PM   #11
bigmac73
bigmac73's Avatar
would you be comfortable giving me a ball park estimate on what is cost to replace that entire floor pan, I have to do the same and have the whole new pan sitting in the garage
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 10-30-2019, 10:13 AM   #12
abohler1
abohler1's Avatar
I would call Dewayne at Nsane Hotrodz. (865) 761-0460
Old 10-31-2019, 07:22 AM   #13
PGSigns
PGSigns's Avatar
So how is the truck coming?
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 10-31-2019, 01:14 PM   #14
Stormin08
Stormin08's Avatar
https://www.youtube.com/watch?v=U84xBWhOaLo
i can personally say this, it ma not take as much space as air, but it does weigh more.
other than that, i doubt i will ever do air again, just the few times i needed to move it around with the battery unhooked...was a pain.
mine usually sat a while, so it aired out before i could get the projects done.
Stormin08 is offline   Reply With Quote
Old 10-31-2019, 06:55 PM   #15
SCOTI
SCOTI's Avatar
I prefer the adjustability of air from a security perspective. It becomes substantially harder to steal a vehicle that's flat on the ground vs. one that can easily be rolled. But, I never liked that air alignment set-points weren't repeatable until the height sensor era. There will always be the nay-sayers but 90psi(F)/40psi(R) when it's 50°F in the AM is not the same as the 90psi/40psi @ 90°F when you got the alignment done. Height sensors changed that but they come @ a cost + you still don't maintain a consistent spring rate unless you're @ the aligned/driving height.
Years ago I brainstormed w/an engineer I worked with (his background was Aerospace & mechanical) about figuring out a way to make suspension mounts that were on a Linear screw set-up (think electronic version of the NASCAR screw-jack but the mount point moves vs the suspension anchor points). That way you adjusted the mount set-point w/o disrupting the alignment & spring rates. I researched the heck out of it but never could find that 'It' item/part that could be adaptable within the space available.
These will definitely end up on my Retro-Rod.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
airride, bagged, hydroshox, lowered, suspension
