Where is the Rear Brake Adjustment Window 69 C20 ??
Went to remove the hub-brake drum assembly on my '69 C20 coil spring HO52. Going to have to backoff the brake adjustment to get the assembly removed. There is no brake adjustment window anywhere, none on the backing plate, none on the brake drum. No knockout plugs anywhere either. Wondering if the brake drums are replacements and the originals had the windows?? Would one of you possibly have an image of an original and the window location?? I'll just cut a window if I know the location........
Steve weim55 Colorado |
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: Where is the Rear Brake Adjustment Window 69 C20 ??
My '72 K20 was the same. We had to fight to get the shoes off, then drill holes in the backing plates for future access to the adjusters. The holes have rubber plugs in them now.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
![]() Join Date: May 2010
Here's a picture of mine, also a '69 C20 coil spring H052. I don't recall ever replacing the drums, but to be sure I'd need to check the receipt file. The truck has 119,XXX miles and most miles were highway.
Hope this helps. Jim |
#4 | |
#5 | |
Jim |
20' Daredevil (Ret)
Good luck with it Steve, I hope you find some knockouts. Mine absolutely did not have them.
#7 | |
#8 | |
don't expect that plug to come out easy mine gave up quite a fight, mine was really in there
The Older Generation
It isn't really a plug because it isn't cut all the way through. They just mark the location. LockDoc
#11 | |
![]() Steve weim55 Colorado |
Steve............try this place in California for your rear drums and brake components. Go to www.inlinetube.com and take a look.
I bought mine (1/2 ton from rock auto), returned 3 sets b/c they were cracked, b/f I got a good set
