Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 05-09-2016, 06:45 PM   #51
rusty76
rusty76's Avatar
Re: 1960 'Burb Revival (First Post)
Cool ride. Late to the game as usual but I'll follow.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 05-12-2016, 01:41 AM   #52
The_Hub
The_Hub's Avatar
Originally Posted by notsolo View Post
Looking Good Andrew..Another Great Burb saved...Are you going with fuel tank, with internal pump. Since you have and X frame, rear is wider than 63-66 trucks. I used a 93 Caprice ( Wagon )..22 gallon poly tank. Just an option don't know if the in tank fuel pump has enough pressure for later model LS motor....Ed
I'm using a Walbro 255 pump and a 25 gallon suburban/k5 tank. Also using the corvette regulator/filter.
Welcome aboard. You haven't missed much yet.
"There are seven days in a week. Someday isn't one of them."
http://67-72chevytrucks.com/vboard/s...d.php?t=686078
The_Hub is offline   Reply With Quote
Old 11-12-2016, 11:43 AM   #53
The_Hub
The_Hub's Avatar
Here comes the picture update thread!!
The donor:
Cleaning up the engine, pulled the intake to give the knock sensors attention and re seal the top end.
I just had to test fit the headers!!
I'll give someone $20 to drink it.
Knock sensors have a problem with filling up with water on the truck engines.
Working down the stock wiring. Couldn't see myself paying $500 plus for and engine harness.
All cleaned up and dropped in.
Now to where it's at currently.
There's a lot missing in the middle there but I'd be here all day typing it out.
The list was huge when a buddy came over to help me get it back up to speed.
Here's what we've got left:
Run fuel lines
Connect wiring
Master cylinder
Cold air intake
Mount filler neck
FIRE IT UP!
The list is significantly shorter than it previously was. Stay tuned!
Old 11-12-2016, 12:06 PM   #54
Advanced Design
Advanced Design's Avatar
Just catching up on the thread. Great project and I will be tagging along for the rest.
Advanced Design is offline   Reply With Quote
Old 11-14-2016, 04:20 AM   #55
The_Hub
The_Hub's Avatar
So this weekend was productive.
Got the heater core mounted and all the coolant lines hooked up.
Fuel tank is mounted and all of the fuel lines are plumbed.
Next up is looming all the wires. Maybe cranking next week.
Old 11-14-2016, 03:23 PM   #56
Ta2Don
Ta2Don's Avatar
Looking good Andrew!!! Progress...
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline   Reply With Quote
Old 05-27-2019, 01:54 PM   #57
blackbart63mule
blackbart63mule's Avatar
Did You ever get a chance to go Burb camping?
Black Bart-63 panel http://67-72chevytrucks.com/vboard/s...d.php?t=664660
blackbart63mule is offline   Reply With Quote
Old 11-05-2019, 12:11 PM   #58
The_Hub
The_Hub's Avatar
I actually sold this ole girl early 2017 when I got orders to Hill AFB Utah. I may look at starting a build thread for my '90 Suburban cummins swap.
