11-09-2019, 11:31 PM | #1 |
67 panel truck neutral safety
my panel truck will start in any gear, is this an adjustment to fix or replacing the switch.
thanks |
11-10-2019, 12:11 AM | #2 |
Re: 67 panel truck neutral safety
Which transmission and engine do you have?
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
11-10-2019, 01:02 AM | #3 |
350 sb and a turbo 400 trans
11-10-2019, 08:39 AM | #4 |
Should just be an adjustment
11-10-2019, 11:10 AM | #5 |
The Older Generation
There are two small hex head screws that hold the NSS switch to the lower column. I have seen both 1/4 and 5/16" heads on them. All you need to do is loosen them up a little and you should be able to slide the switch to the right or left. I set mine by blocking the wheels, putting the shifter in reverse and adjusting the switch until the reverse lights come on. This usually gets it aligned properly. Of course you have to be sure that the reverse lights work.... LockDoc
11-10-2019, 02:01 PM | #6 |
This picture shows the switch and the two purple wires hooked to it. (Looking up from next to gas pedal)
Since your truck starts in all gears someone may have jumpered the switch in the past because the switch failed. The switch does not care which purple wire goes to which terminal on the starter safety switch side. The other side of the switch has the back up lights on it. (Second photo. On the door side of the column) So there are four terminals with wires hooked to the switch on the column. Good luck
