#26 |
![]() Join Date: May 2006
Re: 1999 Trans Am 5.7 6 speed
I like ARP bolts in this instance for replacements. If the the bolt is busted flush you might be able to start a hole with a Dremel tool and then use a reverse twist drill bit spinning clockwise in the drill and it will spin right out. That procedure worked for me. A Dremel tool is one tool I really like a lot. It was a lot easier to use a small grinding bit to center a hole for the reverse drill bit I used.
1989 K1500 Chev. EC Original owner; some of the aftermarket parts I've installed are Borla headers, Hypertech chip, Edelbrock water pump, and a Stillen rear disc brake conversion kit. 2009 Hummer H3T 3.7L 5M (sold) 1997 K2500 Chev. EC 7.4L/ 4L80E (sold) 2018 Dodge Ram 2500 HD R/C |
#27 |
It is broken off flush with the manifold so about 1/4” should be visible once the manifold is removed. I usually give the bolts a good stiff bang with a punch before I try to remove them. So the rat should come out fine...haha!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
