Old 11-18-2019, 01:46 AM   #1
Livingstonm
Gearbox spanner wrench
I know most people make something to use but does anyone know what size spanner wrench is needed to tighten up the front part of the gear box any help is appreciated thanks
Livingstonm is offline   Reply With Quote
Old 11-18-2019, 09:35 AM   #2
geezer#99
geezer#99's Avatar
Re: Gearbox spanner wrench
If you posted a pic of what you’re trying to tighten up I’m sure someone could suggest what wrench to use.
Old 11-18-2019, 09:49 AM   #3
Livingstonm
Thank you I uploaded a pic
Old 11-18-2019, 09:50 AM   #4
Livingstonm
The 2 holes in the front take a spanner wrench, but what size
Old 11-18-2019, 10:14 AM   #5
LockDoc
The Older Generation
LockDoc's Avatar
Good thing you posted a picture. I was trying to figure out where a nut would be on the front of a transmission...
If I was going to buy a spanner wrench I would get an adjustable one. I have quite a few steering boxes out, but I can't get out to measure one at this time.
https://www.amazon.com/Universal-Fin...04059106&psc=1
They have 3mm & 4mm pin ones. Whatever that is.
LockDoc
Leon
Old 11-18-2019, 10:28 AM   #6
Livingstonm
I plan on buying a adjustable one just dont know what size pins it requires was hoping someone has one laying around and could slide a drill bit in the holes in tell me what diameter I need
Old 11-18-2019, 11:51 AM   #7
jeffahart
jeffahart's Avatar
You can probably use an adjustable Gland Nut wrench. This one has 1/4 and 5/16 pins.
https://www.amazon.com/OTC-1266-Adju.../dp/B000X8EGZE
j
White K20
jeffahart is offline   Reply With Quote
Old 11-18-2019, 04:36 PM   #8
projectking
projectking's Avatar
Brass drift and a hammer, I’ve had plenty apart for rebuilding and never needed the spanner.
68 GMC C3500 Longhorn DRW
67 Chevy C10 LWB
90 Mustang Gt
90 Mustang Notchback
projectking is offline   Reply With Quote
Old 11-18-2019, 06:26 PM   #9
Livingstonm
I'm aware there millions of ways to tighten and loosen it just figured someone has had to use the correct tool, I'm just going to use 3 bolts and 2 pieces of steel swiveled with one bolt
Old 11-19-2019, 10:16 AM   #10
57taskforce
All about them K’s
57taskforce's Avatar
Regardless of what to you use to get the front nut loose, make sure you take the jamb nut loose first. That inner nut that takes the spanner won’t budge if the outer jamb is tight.
Tyler
Old 11-20-2019, 08:42 AM   #11
Mike C
Mike C's Avatar
LockDoc
I thought he was working on a Muncie car 4 speed which DOES have a nut and use a special wrench. Also glad he posted a pic of steering gear helped explain!
https://5speeds.com/cart/index.php?r...&product_id=70
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
