#251 |
Re: My 86 build
great work! You're extremely talented!
1983 Chevy C10 250/3spd (current project truck) 1976 Chevy C10 350/350 Heavy Half (future project truck) |
#252 |
![]() Join Date: Oct 2014
Re: My 86 build
Thank you! I never thought of myself being talented, just OCD
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
#253 |
Re: My 86 build
Got the Lower Door Panel Carpets done. Put the stainless steel trim on. Dyed the vents Charcoal.
#254 |
Re: My 86 build
Got the Buckle center belts in. The belts I found were in really nice shape, other than this frayed section. So I cut it off, since it was close to the end, and sewed it back up. That repair is done and all the belts are mounted in the truck.
#255 |
Re: My 86 build
This has been a long time coming, finally got my Jack & Tools mounted, along with a new sticker.
#256 |
Re: My 86 build
My Door Panels arrived this weekend. But before I install them, I知 going to replace my door pins & bushings. I知 waiting on a few tools to help aid with the removal of the pins, and the other tool helps with the placement of the bushing.
#257 |
Re: My 86 build
So the other day, when I installed the Jack Tools where they are mounted on the right side engine room, I noticed the battery try was looking a bit shabby. So I removed it, and I知 going to sandblast it and repaint it, along with the bolts.
#258 |
![]() Join Date: Jul 2009
Re: My 86 build
Yep, I did the exact same thing on Belushi.
#259 |
Re: My 86 build
Since I have the tray out, I found a bolt missing, the lower radiator support to the inner fender. Shame Shame😮
#260 |
Re: My 86 build
#261 |
Re: My 86 build
Well I went to get the receipt to find out, because I致e had the sticker in an envelope for several years. And I just got it out the other day, and the receipt was with it. I must have mistakenly thrown it away, because I can稚 find it now.
#262 |
Re: My 86 build
Had decent day out, so I sandblasted the Tray and Bolts. Spray the tray with undercoating, since it looked like that痴 what was on it already. Also got a tray mat and new positive connection. I would like to find an original looking, but this will do until then. All back together!!
#263 |
Re: My 86 build
10-4 if you happen to remember please let me know
#264 |
Re: My 86 build
Or if I find the paper, I know I have just misplaced it. I keep everything for my truck.
Update:I found a part # 15594820 https://www.ebay.com/itm/1985-86-CHE...4AAOSwlgJdDnzA
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR Last edited by TKCR; 11-22-2019 at 11:07 PM. |
#265 |
Re: My 86 build
Changing out the pins & bushings on the doors. The PO seemed to think it was easier to tack weld the pins to the bottom of the hinge bracket, rather than just put back the C-clip! My brother came up to help, we ended up taking the door off by unbolting the hinge brackets. That gave us a little more room to use a Dremel and grind off the welds. Several hours later, we finally got the pins out!! Well, one door that is! While the door is off, I知 going to clean up the door jamb and do some spray paint touch ups. Another day we will reinstall the door and start the process over again, with the other door. 🥵
#266 |
Re: My 86 build
That's too bad about changing your pins and bushings turning out to be such a challenge, but the engine bay is looking great with the refreshed battery tray and tire tools!
Rick 78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel 71 GMC C25 350/TH400 - Project Angie 59 Chevy SWB Stepside (next in line? Not sure now ![]() 2001 GMC Sierra K2500 |
#267 |
Re: My 86 build
Where did you get your door panels? I am looking for a set of original door panels for my 83. I don't mide if the are not new. I can redo them.
#268 |
Re: My 86 build
USA1 Industries. They are new
#269 |
Re: My 86 build
Thanks so much. I will take a look.
#270 |
Re: My 86 build
Look good....Time to start saving my pennies!!!!
#271 |
Re: My 86 build
I think I知 going to just replace the entire hinges. I was thinking they may be bent. The PO was using a lot of shims. So I ordered some just to compare them with mine, and I think there is a chance that they are bent. I知 not crazy about using aftermarket hinges, but they seem well made and identical to the OEM.
#272 |
Re: My 86 build
While I was waiting on the new hinges to arrive from Classic Parts, I changed out the SPID in the glove box. I have only had this for about 3-4 yrs. I had it made primarily to change the interior color, from Burgundy to Charcoal, since that’s what I did with the interior. Had the SPID made here: http://outintheshop.com/2.html
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR Last edited by TKCR; 11-22-2019 at 11:09 PM. |
#273 |
Re: My 86 build
Got the hinges sandblasted just enough to etch them. Primed and then paint.
#274 |
Re: My 86 build
Nice.. Let us know how they work once installed.
#275 |
Re: My 86 build
Thank you. I will. I知 anxious to get this door back on, and see how everything lines up.
