Old 11-22-2019, 11:43 PM   #1
dmack91
dmack91's Avatar
Clutch Fork Travel Question
Hello all.
Trying to figure my hydraulic clutch problem out. Can anyone confirm how much travel I should have at the clutch slave cylinder/throw out fork? I'm getting about 1/2". I have searched and I found only one reference that said 1 to 1 1/8".
Truck is an 83 K20 that was a diesel converted to gas, SM465/NP205. Lots of cobbled together pieces, including the clutch being converted to hydro using stock components.
I thought lost the clutch last week, could barely get it into gear. Clutch would only disengage at the very bottom of the pedal travel, if at all. Now thinking it may be the hydro system and checking if isn't getting enough throw.
Thanks for the help.
68 Chev C20- son has it now
83 K20 - bought from son
70 C20 - in progress
dmack91 is offline   Reply With Quote
Old 11-23-2019, 10:27 AM   #2
v30crewcab
v30crewcab's Avatar
Re: Clutch Fork Travel Question
sometimes the pushrod gets bent. also, take off slave, and push it in and out to bleed it. if the fluid got low it might have got an air bubble in it.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 11-23-2019, 11:05 AM   #3
CANUCIT
CANUCIT's Avatar
as the clutch wears there is more travel, you might have to put in another shim
1962 chevy short and wide
2015 z71
1967 SS Chevelle
CANUCIT is offline   Reply With Quote
Old 11-23-2019, 01:49 PM   #4
dmack91
dmack91's Avatar
Nothing is bent and I just put in a new clutch. Getting ready to try to bleed the system now.
Old 11-30-2019, 01:13 AM   #5
1774btcrew
1774btcrew's Avatar
The rod as well as the Z bar will get grooves worn in them and not engage the clutch as far.
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline   Reply With Quote
Old 11-30-2019, 11:56 PM   #6
nonstop
Hydro system would be my first guess. I lost a master once and a slave another time or two. Both times, I progressively lost my pedal until the clutch would not disengage.
nonstop is offline   Reply With Quote
Old 12-01-2019, 12:22 AM   #7
1774btcrew
1774btcrew's Avatar
They weren't hydraulic until 1985. Doesn't mean it couldn't have been changed at some point
Old 12-01-2019, 01:29 AM   #8
dmack91
dmack91's Avatar
Thanks, IT is a hydro system. Bleeding the system got me going.
Old 12-01-2019, 01:47 AM   #9
1774btcrew
1774btcrew's Avatar
That is nice it has been upgraded to hydraulic, I like that system better
Old 12-02-2019, 02:29 AM   #10
nonstop
Might want to go ahead and replace both components. The system got air in it somehow (possibly from a bad seal) and will likely get more air in it again.
Old 12-02-2019, 09:55 PM   #11
dmack91
dmack91's Avatar
I should have replaced the slave too, I know, but was trying to get it back in service before the snow arrived. Going to pick up a mityvac tomorrow as I'm still fighting air in the system. Laying under it in 12" of snow leaves a lot to be desired.
