Old 11-23-2019, 08:42 PM   #1
lynx5653
lynx5653's Avatar
fender extension rivets
what rivet do I use to attach fender extension to fender ? 55 2nd
1955 2nd on 86 chassis
Daily driver
lynx5653 is offline   Reply With Quote
Old 11-26-2019, 05:59 PM   #2
lynx5653
lynx5653's Avatar
Re: fender extension rivets
OK guess no one knows the answer I will figure something out.
Daily driver
Old 11-26-2019, 07:32 PM   #3
sack54
lookup aircraft rivets they work and look just like what you are looking for.
https://www.hansonrivet.com/?gclid=C...EaAsUZEALw_wcB
sack54 is offline   Reply With Quote
Old 11-26-2019, 10:14 PM   #4
ndeep
i am just using stainless screws, installed after painting and installation
ndeep is offline   Reply With Quote
Old 11-28-2019, 03:16 PM   #5
_Ogre
_Ogre's Avatar
i don't think anyone knew what you were asking
a picture is worth a 1000 words
shop air compressor timer
Old 11-28-2019, 03:52 PM   #6
dsraven
just be sure to test fit so there is not an interference fit with the hood on those corners. I used pop rivets for quick assembly to get stuff stuck together and found the large headed rivets i used were too thick and the hood interferes.
not a very good pic but it does show the big rivets I used just because they were handy. I plan to use thin headed rivets when the time comes.if it ever comes, lol.
hope that helps explain, like ogre says, a pic is worth, you know.
Old 11-29-2019, 02:51 PM   #7
lynx5653
lynx5653's Avatar
I will just use jb weld and clamp it tight till it sets up. wont have to worry about rivet size then
Daily driver
Old 11-29-2019, 05:06 PM   #8
dsraven
kinda painful to watch, and you may wanna order birthday cake, because you may have another birthday before he is done talking, but this is what I will likely do. same principle as an aircraft rivet.
https://www.youtube.com/watch?v=FnBZltkXqT0
Old 11-29-2019, 08:54 PM   #9
DransportGarage
DransportGarage's Avatar
Well, if you're gonna do that you might as well just plug weld 'em with a MIG. At least if you want to get them apart again you'll be able to drill the welds out rather than cut the flanges off.
Bob
"It won't take long and it won't cost much."
'55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed)
Bob's Retirement Build - My 55 TF
Bob's 700R4 Build (how-to)
DransportGarage is offline   Reply With Quote
Old 11-30-2019, 02:06 AM   #10
dsraven
thats exactly what I was just thinking. plug weld them and be done.
Old 11-30-2019, 10:33 AM   #11
lynx5653
lynx5653's Avatar
good idea about plug weld if I had a welder and could weld. Thought about aircraft rivets ,but having to buy a 1-2 hundred dollar tool to set them isn't worth it. The link about the aluminum seamless rivet idea just seems it would be quite difficult do .don't ever plan to replace them again or have a need to take them apart might just use snap rivets just more of them. So thanks for your ideas.
Daily driver
Old 11-30-2019, 02:13 PM   #12
_Ogre
_Ogre's Avatar
still don't know what fender extensions are
Old 11-30-2019, 02:47 PM   #13
NorCalGal
NorCalGal's Avatar
Not sure exactly what you’re needing but I recently order these from the filling station in Lebanon, Or
Jan's 53
NorCalGal is offline   Reply With Quote
Old 11-30-2019, 02:48 PM   #14
NorCalGal
NorCalGal's Avatar
The one on the right has more dome and is stainless.
Jan's 53
Old 11-30-2019, 04:52 PM   #15
lynx5653
lynx5653's Avatar
Ogre,
they are a filler piece on 55-57 trucks between fender and rad support
Daily driver
Old 12-01-2019, 02:02 PM   #16
_Ogre
_Ogre's Avatar
thanks for the pic, nothing like it on 58-9
