11-25-2019, 03:07 PM | #1 |
Help! What's the deal with this brake booster on my 72 GMC?
Ordered a new brake booster for my 72 GMC 1/2 ton. See pictures attached. Bolt pattern on the old one looks to be 4", and the new one is 3 3/8". I don't see any options for different boosters to buy. Any idea why my old one has a different pattern? Thanks!
1972 GMC Sierra Grande (current truck) 1980 Chevy Stepside (gone) 1987 Chevy Blazer (gone) 1972 Chevelle SS Convertible (gone) 1973 Chevy Corvette (gone) 1967 Chevy Camaro (STOLEN!) |
11-25-2019, 04:01 PM | #2 |
Re: Help! What's the deal with this brake booster on my 72 GMC?
bracket
11-25-2019, 04:03 PM | #3 |
I'm hoping that for some reason I have the wrong brackets. No idea what this booster is from if that's the case. Just ordered this from Jegs.
https://www.jegs.com/i/JEGS/555/631022/10002/-1
11-25-2019, 04:03 PM | #4 |
Your new one is a China repop that requires the repop bracket also
1957 CHEVY 1/2 TON SHORT BED 1940 FORD 1/2 TON SHORT BED |
11-25-2019, 04:22 PM | #5 | |
Hopefully the bracket I got from Jegs will fix the problem.
11-25-2019, 04:55 PM | #6 |
You better cancel those brackets. They're for a 67-72 Chevelle
11-25-2019, 04:56 PM | #7 |
Most people buy the booster with the truck bracket as a set.
11-25-2019, 04:59 PM | #8 |
This one on Ebay: https://www.ebay.com/itm/1967-1972-C...IAAOSwOTNZ1V-4
11-25-2019, 05:25 PM | #9 | |
11-25-2019, 06:20 PM | #10 |
Go Pack Go!
Get ahold of Frank (pickmup) in Washington State. He builds power brake boosters that are better than factory.
11-25-2019, 09:08 PM | #11 |
I found that out the hard way as well. I could not find a rebuilt booster so I bought the whole kit and tried to use new booster on oem brackets and they were different sized. I used all the conversion setup except the pushrod because the original one looked WAY more heavy duty.
11-26-2019, 06:44 PM | #12 |
Screw it. Ordered a reman unit from O'Reilly. Should be here tomorrow. Won't look as good as a new one, but should bolt on. Hope I can return the Chinese one to LMC without too much trouble....
