Old 11-26-2019, 10:02 AM   #1
jbgroby
jbgroby's Avatar
Making up a cross member
OK, it looks like everything is on track for the trans swap. All I need to do is make up a cross member to support the rear of the 700R4. I wanted to ping the group and get your ideas, thoughts and suggestions as to how you would do one.
Because I have the 1960 GMC X-frame I cannot use any aftermarket (bolt in - no one make any so I'm told).
My idea is to purchase 2" x 2" angle and welld it to the inside of the X-frame and then bolt AND stop weld a cross member, I only have to span 12".
Has anyone had to custom rig a cross member?
Jake
jbgroby is offline   Reply With Quote
Old 11-26-2019, 10:07 AM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Making up a cross member
Here is a link where markeb01 sectioned one - http://67-72chevytrucks.com/vboard/s...d.php?t=665342
And a link where a member fab one up - http://67-72chevytrucks.com/vboard/s...d.php?t=423575
Old 11-26-2019, 10:49 AM   #3
jbgroby
jbgroby's Avatar
Thanks Rocknrod!
Old 11-26-2019, 02:55 PM   #4
jbgroby
jbgroby's Avatar
OK, I was over thinking the problem, I'm going to bolt a C-Channel across the span and use a space block under the mount if needed. Sometime you cant see the forrest for the trees......
Old 11-26-2019, 05:29 PM   #5
forestb
forestb's Avatar
Speaking of Forest that's what I did. If I new how to weld I would have used square stock and welded a bracket to the side of it to drill the holes in. I think bolting it down to the c channel weakened it more than I would like.
forestb is offline   Reply With Quote
Old 11-28-2019, 01:06 AM   #6
LVPhotos
LVPhotos's Avatar
I know its a manual but same bar type can be done. I had flat 1x4 square box on t5 on bottom of frame and this Porterbuilt cut and welded to fit mine inside frame.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 11-28-2019, 01:22 AM   #7
SkinnyG
SkinnyG's Avatar
I copied LVPhotos mount to do my 4L80.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
