11-29-2019, 11:49 AM | #1 |
Advice on new suspension kits
I'm always thinking two or three moves ahead on my truck. Soon to come is a complete suspension upgrade. Right now if feels like I'm going down a trail in a covered wagon when I drive this old gem. I like things stock-ish. No lowering. No bags. None of that. Original look with a comfortable ride. I've looked at the different venders and can't seem to find a complete kit that seems right. Does lowered spindles mean the truck will be lowered? Most of these kits have lowered spindles but I don't want to lower my truck. I want to address the front and back end. I'm getting ready to do manual to power steering upgrade and then the suspension. I welcome your thoughts and suggestions.
Oh...almost forgot : 1968 Chevy C10 Stepside. SWB 307 engine with 4 speed manual |
11-29-2019, 03:55 PM | #2 |
Re: Advice on new suspension kits
If you’re not looking to lower your truck a good set of shock absorbers will possibly be enough to smooth out your ride. If that doesn’t do the job then a new set of stock height coils would be the next step. Assuming of course that you have a coil sprung rear end.
I would also check things like cab mounts, bushes, ball joints ant tie rod ends are not worn out first. Approaching it this way will possibly save you some money against buying a whole kit.
John 69 c20, 396, th400, dana60, ps, ac |
11-29-2019, 04:12 PM | #3 |
KYB gas a just shocks give stock suspension a firmer, but still very nice ride. Which are my personal favorite.
Gabriel has some gas matics ride great, and not too expensive. They give a softer float to the ride which many like too. Shocks are a major point of suspension tuning, and depend on you for the final outcomes. So you have to think about your dreams, and the realities of how you use your truck. Then try to find the best option that makes you happiest. |
11-29-2019, 06:55 PM | #4 |
If you are not looking to change the ride height of the truck, I can't imagine you need any kind of "kit".
Have a front end alignment done to check for loose components. As said shocks would be a good place to start. If yours doesn't have one, a sway bar will do wonders. Used sway bars come up on here for sale from time to time. A sway bar off most GM trucks 1967-1987 will work. A steering box from a 1979 will give you closer ratio steering, and that can be acquired from an auto parts store.
