Old 11-22-2019, 10:31 AM   #1
72velle
72velle's Avatar
New dip stick
Anybody know where I can get a stock Chevy dip stick for a 350?
All I have found in the local parts houses are "close" to being right or cut to fit.
TIA,
Kevin D
72velle is offline   Reply With Quote
Old 11-22-2019, 10:34 AM   #2
Re: New dip stick
Does it have a driver's side dip stick or passenger side one? I got a driver's side one from the local chevy dealer, which fit way better than anything I have seen aftermarket.
Old 11-22-2019, 11:03 AM   #3
72velle
72velle's Avatar
Re: New dip stick
Drivers side. Might have to stop by the dealer.
Old 11-24-2019, 10:47 AM   #4
fordguy40
Re: New dip stick
I'll toss in another vote for getting it at the dealer; cheap and fits like it's supposed to.
A few Fords and a couple of Chevys
fordguy40 is offline   Reply With Quote
Old 11-25-2019, 11:00 AM   #5
72velle
72velle's Avatar
Re: New dip stick
Do you have a part #? Dealer says it’s too old to look up
Old 11-25-2019, 11:04 AM   #6
Re: New dip stick
It's 2 pieces, hope these help
Item
Oil Tube (GM # 12337946)
Gauge Assembly (Dip Stick GM # 3981019)
Old 11-25-2019, 11:56 AM   #7
Dleslie212
Re: New dip stick
Item
Does year matter? Or is this pretty much a universal dip stick? I need a new one for my 77, the one that’s in there is way too loose and the entire tube pulls out when i check the oil
Dleslie212 is offline   Reply With Quote
Old 11-25-2019, 12:27 PM   #8
Re: New dip stick
For those that have the dip stick on driver's side of engine. The hole sizes are different than the ones on the passenger side. Not sure what the cutoff year was for the changeover
Old 11-25-2019, 12:29 PM   #9
Dleslie212
Re: New dip stick
Drivers side on my 77. Thanks for the info
Old 11-25-2019, 01:19 PM   #10
MikeB
MikeB's Avatar
Re: New dip stick
I think they moved it to the passenger side starting with 1980 models. Some blocks and oil pans, like those used on the base Goodwrench 350 crate engine, have provisions for both sides.
Mike
1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress.
1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 11-25-2019, 04:10 PM   #11
RyanAK
Re: New dip stick
If you install a crate engine and use the driver-side dipstick, be sure to correctly plug the hole on the passenger side or you'll have yourself the rare "continuous oil-mist undercarriage rust inhibitor" option installed. The plastic shipping plug is not all that is required. Ask me how I know. And be sure to do this when building the engine on the stand. Before the exhaust manifolds are on.
PO install, by the way... heh.
Ryan
WANTED: '60-'66 4X4 Suburban/Carryall
Meet 'Earl', '71 C10 Suburban - Sold, but not forgotten...
Meet... yet to be named, ‘78 K10 Suburban Daily Driver
RyanAK is offline   Reply With Quote
Old 11-26-2019, 07:34 AM   #12
72velle
72velle's Avatar
Re: New dip stick
Local dealer doesn't have one in stock and says he can't order it because it is discontinued. Can anyone recommend another source?
Old 11-26-2019, 08:06 AM   #13
Re: New dip stick
try ebay
Old 11-26-2019, 10:38 AM   #14
MikeB
MikeB's Avatar
Re: New dip stick
These might be worth a try. Neither one is chrome.
https://www.summitracing.com/parts/s...make/chevrolet
https://www.summitracing.com/parts/m...et?prefilter=1
Found this GM tube, but not a dipstick:
https://www.summitracing.com/parts/n...6870/overview/
Mike
Old 11-30-2019, 07:10 PM   #15
Pontiac1976
Pontiac1976's Avatar
Re: New dip stick
73-79 350 older factory motor dipstick on pass side.
Try motor rebuilder shop local. just tell them what year motor and side dipstick you have Oh and if you changed your bottom end, oil pump, oil pan bigger, or deeper if not stock.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
