Old 12-01-2019, 11:45 AM   #1
RAB38
LSX Swap questions
I am in the process of putting together a swap in my 72 K5. I plan on buying the GM perf LSX 454 crate engine. I plan to mate it to my T-350 trans for a while. May change that to an overdrive down the road.
Questions.
1. What headers will fit best? Looking at hooker’s, schoenfeld, and headmans.
2. What flexplate do i need to mate to my TCI torque converter
3. What front drive accessory system works that is affordable? I would like to reuse my existing alternator, PS pump and my r4 AC compressor. If I cant then thats fine but I would think it should be possible. These are all part of the GM Performance Parts accessory drive kit i have on my 383 SBC.
72 Blazer CST 383 stroker roller, fuel inj, t350,NP205, D60 front, 14b rear, detroit locker, 38 x15.50 mtz's, welds, cross over steering, custom cage,Line X Spray in liner, House of Colors Tangelo Pearl Orange
RAB38 is offline   Reply With Quote
Old 12-01-2019, 12:15 PM   #2
prodjay10
Re: LSX Swap questions
I’m curious to know if you can use the old alternator on the swap. I just used all the accessories except the ac compressor from the donor vehicle. The one issue I feel I’ll have is with the AC compressor which I don’t have installed yet. I’m thinking high mount with a sanden but many have complained about a squeal on this site.
prodjay10 is offline   Reply With Quote
Old 12-01-2019, 12:35 PM   #3
RAB38
Another thing I am thinking through is how to handle the kick down cable for the Th350. Since the throttle body is DBW, has anyone come up with a solution to solve this? Do you just go off the accel pedal?
Old 12-02-2019, 11:08 AM   #4
skyphix
There are a few options
1) Don't run a kickdown cable - downshift manually to pass if needed.
2) Run it off the accelerator pedal - I believe it was GM A bodies did this. You could probably figure out some way to adapt that with a DBW pedal.
3) Convert to a DBC throttle body.
Personally, I was going to do option 1 because I knew that eventually I'd be going OD. I ended up going with a 4L80E right away because I got a good deal on a low mileage one and my TH350 was pretty thrashed.
Eric
1980 C10 SWB
2003 Chevy Suburban 2500 LT
skyphix is offline   Reply With Quote
