Old 12-05-2019, 09:09 PM   #1
fastbagged68
fastbagged68's Avatar
LS1 swap and vhx gauges
So I’m finishing up the LS1 swap on my dads 67 C10. The motor came with a wiring kit that is not the best.... the motor was part of a few project cars that were never finished. I can’t get the obd port to communicate to my scanner. I bought the Dakota digital ob2 connector for the vhx gauges. Won’t work at this point. The cpu has oil and water wires coming from it. Dakota digital says I can’t use those in their module. How are you guys doing your vhx gauges with an ls swap.
fastbagged68 is offline   Reply With Quote
Old 12-06-2019, 10:50 PM   #2
thehata1
Re: LS1 swap and vhx gauges
It's been a while since I did my swap. But, on lt1swap.com, Brendan gives a bunch of different schematics for different years with what wires are needed for the OBD2 port. If you don't use the port, you'll have use old school sensors. everything you need to know for those should be in your VHX manual. I'm happy with my setup, for sure. Good luck!
http://lt1swap.com
thehata1 is offline   Reply With Quote
Old 12-07-2019, 01:33 PM   #3
70c10resto
70c10resto's Avatar
I used the sensors and that came with my vhx gauges. The sensor kit has the adapters need to make them work as well. I used Dakota digitals sensors for the oil pressure and engine coolant temperature, for the tach and speedometer I’m getting signal through the engine harness. I got the oil pressure threaded into the factory spot behind the intake and the coolant sensor is threaded into the passenger head near the rear of the engine.
70c10resto is offline   Reply With Quote
Old 12-07-2019, 08:43 PM   #4
Ghost's68
Ghost's68's Avatar
Just use the OBD port to read info. That’s what I did and can’t beat it for simplicity with no added extra wires.
Ghost's68 is offline   Reply With Quote
Old 12-08-2019, 04:36 AM   #5
fastbagged68
Thanks guys. I ended up using the data port. Now I need to get the truck finished.
Old 01-13-2020, 09:05 PM   #6
67swchevyswb
Beautiful truck
67swchevyswb is offline   Reply With Quote
Old 01-16-2020, 07:47 PM   #7
thehata1
That truck looks awesome. Congrats and keep going!
