Old 12-08-2019, 01:27 PM   #1
bigmoe
bigmoe's Avatar
Where does the horn go?
Doing some reassembly on my 65. Where is the factory location for the horn? Does it go on the front of the rad support inboard of the drivers headlight area? Those two holes with light coming through? (Sorry it’s upside down)
bigmoe is offline   Reply With Quote
Old 12-08-2019, 01:30 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Where does the horn go?
Inside the engine compartment - See this thread showing the horn and the relay:
"If" you use the stock location, the trick is finding brackets that use both hoses there.
http://67-72chevytrucks.com/vboard/s...d.php?t=649925
Old 12-08-2019, 01:59 PM   #3
bigmoe
bigmoe's Avatar
Thanks. I might try to find somewhere to hide it. I’m trying to clean up the engine compartment, hiding the wires, etc.
Old 12-08-2019, 02:33 PM   #4
sstock
sstock's Avatar
hoses? you mean holes?
1953 3100 261cu in, sm420, 3.55 torque tube, omaha orange
1964 GMC 1000 series,custom, 305E, sm420
sstock is offline   Reply With Quote
Old 12-08-2019, 02:47 PM   #5
The Rocknrod
Moderator
Behind the headlights there is plenty of room.
Old 12-08-2019, 09:14 PM   #6
bigmoe
bigmoe's Avatar
Good to know. Good place to hide it away.
Old 12-09-2019, 12:04 PM   #7
jeff_wilson70
jeff_wilson70's Avatar
On my 66 I had dual horns (high and low) and they were mounted beneath and inboard of the grill support, between the frame rails.... pretty much under the radiator. I'm not positive that it was factory, but they looked like they had been there for quite some time.
jeff_wilson70 is offline   Reply With Quote
