Old 12-12-2019, 11:52 AM   #1
maverickmk
maverickmk's Avatar
GMC/Leaf Spring Axle Flip Lit - ?
Anyone with leaf springs use an axle flip kit like this one to lower your truck?
https://djmsuspension.com/product/fk1012-5/
How much did it drop it? Are they solid, sturdy?
Die with memories, not dreams.
Not to brag, but I don't need alcohol to make really bad decisions.
1969 GMC Short Step Side
maverickmk is offline   Reply With Quote
Old 12-12-2019, 09:04 PM   #2
Rufas
Rufas's Avatar
Re: GMC/Leaf Spring Axle Flip Lit - ?
I did a flip kit early on my 70 GMC 2500. I removed all but one leaf to get the drop I wanted. I felt that setup was extremely weak and might have a lot of axle wrap.
I finally decided to get rid of the leaf springs completely and went RideTech's Strong Arm bolt in 4 point trailing arm suspension. Glad I and no regrets.
[/url]
1970 GMC 2500
700R Trans, RideTech 4 link rear suspension, air bagged on all four corners, factory upper/lower A-Arms, 2 inch drop spindles.
350 SBC 300hp
Weiand Supercharger
FiTech 30004 EFI
Rufas is offline   Reply With Quote
Old 12-12-2019, 09:07 PM   #3
maverickmk
maverickmk's Avatar
How low does a flip kit go? I'm looking to get 3-4" at the most.
Old 12-12-2019, 10:13 PM   #4
Rufas
Rufas's Avatar
Take the height of the axle perch pad and the diameter of the axle tube. Add those two values together and that will be the amount you will lower your truck when the axle has been flipped.
1970 GMC 2500
350 SBC 300hp
Weiand Supercharger
FiTech 30004 EFI
Old 12-12-2019, 10:38 PM   #5
lobuck64
I got a 65 GMC using a rear axle out of 75 C10 so using a flip kit for 73-87 c10 p/o put Nova rear axle under it but I didn't like that set up hope to have it all together this weekend
lobuck64 is offline   Reply With Quote
Old 12-13-2019, 08:51 AM   #6
maverickmk
maverickmk's Avatar
Thank you for answering a question that if I had just taken a minute to use my noggin I could have figured it out on my own
Feeling like a doofus now.
Old 12-13-2019, 04:09 PM   #7
dagnabbitt
dagnabbitt's Avatar
I did an axle flip on my 81, it went much much lower than 4 inches. It was more like 6. I dropped the front 4 1/2 too using spindles and shocks. I plan to basically do the same thing with my 70 stepper if I can get my act together.
If you are just looking for a mild drop an axle flip is probably not what you want IMO.
But maybe you bite the bullet and slam that truck! Most people in my experience who start off with a mild drop end up dropping it even further later on.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 12-13-2019, 07:43 PM   #8
Mike C
Mike C's Avatar
I used the DJM flip kit on my 69 short step. It dropped the truck 7 1/4" with the HD springs that my truck has. 4 leaf instead of 3 I think? I am running CalTrac bars and removed the overload because it hit the bars, but that has no bearing on the lowering amount.
4 1/2" drop in the front with ECE spindles and springs.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 12-13-2019, 08:02 PM   #9
maverickmk
maverickmk's Avatar
There it is! That's what I wanted to see. I didn't want to get new spindles, but it's looks like that will "have" to be done
Old 12-13-2019, 08:29 PM   #10
Mike C
Mike C's Avatar
I had a specific goal in mine and that started with disc brakes which need spindles anyhow, so dropped made sense.
The 275 55 17 tires in the back on 17x9" wheel with 5" bs required the wider axle from a 71-72 truck to put the wheel in the right spot. I am running the urethane puck bump stops that came with the kit and have not c-notched. It hits the stops sometimes but really a non-issue.
I am running 4 stock length front shocks. In the rear I re-drilled the upper mount plate to put the shock in the more vertical 2nd hole. I think I may have run a 69 Camaro multi-leaf shock mount in the hole? Don't remember now.
On the front it has 17x8" wheels with 4.5" bs and 235 55 17. I added a sway bar from a parts truck I had but bought the ECE sway bar lowering brackets.
44 Willys MB
52 M38A1
64 Corvette Coupe
