12-16-2019, 10:42 AM | #176 |
Re: 1968 GMC - Ol' Blue
I got a few little things done this weekend - mirrors, locks, door handles, and VIN tag are on. I had to file on the driver side lock hole in the door to get the lock in; that was painful. Also have most of the front lights wiring done, just don't have lights to hookup yet.
I buffed my old front bumper a little bit, but decided it would look bad next to the fresh paint and compared to the new rear bumper so I'll have to order one. We finished out the day and took it for another short drive. I like to take it for a spin whenever I can to get the bugs out. The tach isn't working right though, it seems to be reading low and it has quite a delay so I need to figure that out eventually. I don't know what the tuner set it for but I might be able to fix it through programming the gauges. Progress is going to be a little slow for the next couple months with Christmas and having to buy a bed soon. Next steps will be the sound system and some lighting, maybe a new front bumper and glass.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632 1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047 1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184 1978 Chevy Scottsdale K20 1993 Chevy C1500 - 5.3/T56 swapped 2008 Silverado Duramax |
12-16-2019, 11:35 AM | #177 |
Looking good man. How did you clean up your vin tag?
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444 "It's only money". |
12-16-2019, 12:04 PM | #178 |
Looking good. You got a lot done since last time I checked.
Former Build (68 c10 swb): http://67-72chevytrucks.com/vboard/s...d.php?t=724379 (SOLD) Current Built (68 c10 swb): http://67-72chevytrucks.com/vboard/s...d.php?t=787712 |
12-16-2019, 12:24 PM | #179 |
I just sprayed some glass cleaner on it and wiped it off, it was in pretty good shape already. I might hit it with some metal polish one of these days if I really want it to shine.
12-18-2019, 11:36 AM | #180 |
Looking good, you gotta love that blue in the sun.
12-18-2019, 03:55 PM | #181 |
Almost Satisfied
Truck looks hot on a chilly day in Western Colorado! You have came a long ways in what seems like a short time. Hoping to get back on mine after the first of the year. Wife decided she needed new windows for the house....
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
12-18-2019, 04:02 PM | #182 |
Thanks guys. That day, the sun came out for about 10 minutes just as I was finishing up a couple things to take it for a spin. I have to get it done before I get married because it won't be as easy to spend time and money on projects after that. At least that's what I'm told!
12-20-2019, 01:04 AM | #183 | |
Brian
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
01-01-2020, 11:49 AM | #184 | |
Looking great, you have come a long way this year... |
01-02-2020, 10:38 AM | #185 |
Happy New Year everyone!
My dad and I had the day off yesterday and we got a lot done on the sound system. We built an enclosure to take place of the stock fuel tank (using the fuel tank mounting holes) to house two subs and two speakers and the amp, wrapped in vinyl. The subs are shallow 10" driven by a 1000W amp and the speakers are 6" components. I have slightly smaller speakers to install in the front kick panel vents next and the system will be complete. The specs on the subs indicate a minimum box volume of .35 cu ft and I'm at .44 so it worked pretty well. The system (even without front speakers) sounds great. They are slim subs with small boxes, but I'm not looking to shake the truck apart, just get some good bass. When we modified the dash, we used a double din sleeve from an Alpine double din unit we had laying around. What I found while looking for a head unit was that Alpine seems to be consistent with their chassis size, so the head unit I bought fit perfect in the sleeve. I like this iLX-W650 because it's so shallow, light, and affordable. The only trick with it is that it's got a safety feature in which a lot of the functions and settings are unavailable unless the parking brake is on. However, "parking brake engaged" is a relative term - it just means that the unit needs to see a ground on the parking brake wire in order to unlock those functions. But it can't be a constant ground, the unit needs to see the ground appear after it's turned on. So I just ran it to my ground buss bar under the dash and installed a toggle switch in line so I can fool it whenever I need to. No relay or microbypass needed. My console also arrived - it was pulled out of a 14-18 GM pickup/SUV before it went into service for law enforcement so it's basically brand new and fits perfect between the seats. They robbed the USB and charging ports out of it, but my head unit came with a USB cable that I ran under the carpet so I can plug my phone in from the console and charge or use Apple CarPlay. I know some guys are cringing at the quantity of speakers and the modified dash, but I value a good sound system and I love the double din receiver.
01-02-2020, 11:22 AM | #186 |
Almost Satisfied
Speaker box looks good. Giving me ideas...
01-02-2020, 12:03 PM | #187 |
Yeah I like the speaker box too. But those look like coax speakers not components... Components normally have the crossover box and tweeters mounted outside the mid-woofer? I'm no expert, just been doing a lot of research for my truck. I'm really happy to hear your details having .44 cu ft. Makes sizing subs easier for me now
I plan to do something similar. I like the idea of the new speaker mounts in the cab corners from brotherstrucks but not sure about that yet. I plan to do components in my doors and remote mount the tweeters somewhere higher in the door. Or maybe put them in kick panels only. I dunno. P.O. cut holes in the door for 6x9's so..... Sweet man
01-02-2020, 12:25 PM | #188 | |
01-05-2020, 03:01 PM | #189 |
I have the same speaker in a 10 inch version, only one of them, in my daily driver... a single cab Sierra. It rocks flat out in such a small space. With those 2 subs, you’re liable to shake the fillings out of your teeth. Looks great, as usual.
01-06-2020, 10:08 AM | #190 |
Thanks. I'm not going for a bumping system so it's a little overkill, but I wanted it to be symmetrical and have plenty of adjustment.
01-06-2020, 10:18 AM | #191 |
The front end lighting is done. I bought the halogen upgrade headlights from LMC and I'm pretty pleased with them. They use a modern 9007 lamp and I opted for the blue-coated lamps for whiter light. Working with 4 headlights makes me jealous of you Chevy guys - it's twice the struggle and there's barely enough room in front of the core support for the housing and lamp pigtail so the wires are almost stressed on the inners. Also, I couldn't remember how the spring hooked on the buckets so I fought that for awhile.
But the LED sidemarker lights from SOKY were easy to install and look great too. I need to figure out how to reset the glass in the channels though. I haven't been able to find much info on this task yet. It seems from the factory they were just pressed in with some rubber without any adhesive. I ordered the "glass setting rubber" from LMC and it's basically just strips of rubber. The passenger glass fell out of the channel during door disassembly so I took the driver side apart and sandblasted and painted the channels while I was at it. If anyone has any tips on this, let me know please.
01-06-2020, 10:55 AM | #192 | |
01-06-2020, 11:46 AM | #193 |
Almost Satisfied
Potter, I'm trying to change out the fittings on my Astro Hydro unit. Do you have any idea what size the fittings are? I'm thinking I need the RUS-648060 for the Input and the RUS-648080 for the output, but don't know for sure. I also can't find what the size of the low pressure return fitting is.
I want to put new fittings that will 90 out and give me more control over where my lines run. Thanks
01-06-2020, 12:17 PM | #194 | |
http://www.hydratechbraking.com/hose_fittings.html
01-06-2020, 02:00 PM | #195 | |
01-06-2020, 02:22 PM | #196 |
So you didn't use any rubber? Just glued it to the channel?
01-06-2020, 02:34 PM | #197 |
Yep
01-06-2020, 02:47 PM | #198 |
I just ordered a tube of 3M windshield adhesive, wish me luck!
01-09-2020, 04:18 PM | #199 |
The truck's looking good!
What seats are you going to use with that console?
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
01-09-2020, 04:39 PM | #200 |
Thanks!
I'm using the 04 Escalade buckets. They're graphite so they won't match everything else, but they're fine for now since I'm going to recover them eventually.
