Old 12-18-2019, 03:49 PM   #1
1972BackInBlackC10
1972BackInBlackC10's Avatar
Lower Control Am U Bolt question
Will lower control arm bolts from a square body chev work on the 67-72 lower control arms? The one im wondering about are in this link below, it says the thread size is 9/16-12 in. and the length is 3.250 in.Iv seen posts where people have been using the larger 9/16 size but im not sure if these are the ones since I cant seem to find much for u bolts
https://www.summitracing.com/int/par...on/front-lower
1972BackInBlackC10 is offline   Reply With Quote
Old 12-18-2019, 06:12 PM   #2
Jason Banks
Jason Banks's Avatar
Re: Lower Control Am U Bolt question
Dorman 13503.
Those are the ones I used. Had to drill out the holes to fit.
Jason Banks is offline   Reply With Quote
Old 12-18-2019, 06:17 PM   #3
68 P.O.S.
Yes, 9/16 is the correct size to upgrade to for safety. The originals were 7/16 or 1/2 and there were problems with them snapping while in reverse with the wheels cranked all the way in either direction. I had this happen and it was a pretty scary drive.
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 12-18-2019, 11:06 PM   #4
bean
I used those as well on my 72. Didn't have to drill them out though.
bean is offline   Reply With Quote
Old 12-22-2019, 10:31 AM   #5
Andy4639
Old member
Andy4639's Avatar
Question Re: Lower Control Am U Bolt question
I've had my 71 for 37 years with the factory u bolts and never have had a problem with them. The ramp truck has them and no problems the 68 still has them also. No problems but it's not on the road yet though!
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
