Old 12-21-2019, 03:54 PM   #1
desert-rat
Location: 3,018 feet above the SoCal/Mojave Desert region.
How to use a remote starter button.
So I purchased a remote starter button. One wire connects to the starter and the other to the battery, right??
I have the cab off but the engine still on the frame. So there for no ignition cylinder. Will the engine turn over or just crank??
Videos keep saying to have the ignition in ON to start the motor, but cant with out an ignition cylinder.
Thanks.
desert-rat is offline   Reply With Quote
Old 12-21-2019, 04:37 PM   #2
Getter-Done
Getter-Done's Avatar
Re: How to use a remote starter button.
Your 1st question.
Yes connect one lead on the remote start button to terminal (S).
Connect the other to the positive side on the battery.
You could connect them both on the starter But if they touch
Your 2nd question
If you do not have 12volts running to the distributor it will not start.
Okay now
Before you turn the engine over !!!!!!!!
Make Sure it is in neutral (if it is a straight shift) or Park (if automatic transmission)
What are you trying to accomplish? Hear it Run?
Is it HEI ignition or point type?
84 Chevy K-20
Last edited by Getter-Done; 12-21-2019 at 05:31 PM. Reason: Type Wrong info for Letter
Old 12-21-2019, 05:17 PM   #3
desert-rat
Thanks for the reply. It's an HEI type. How do I get 12 volts running to the distributor and from where? I am selling the motor and want the buyer know that the engine can run.
Old 12-21-2019, 05:23 PM   #4
HO455
HO455's Avatar
The S terminal is the one to hook the remote switch to to operate the solenoid.
The R terminal is to forward 12 volt positive to the coil when the starter is cranking.
RIP Bob Parks.
Old 12-21-2019, 05:25 PM   #5
Getter-Done
If this picture doesn't help
I will try to find another.
Most caps have writing on the top or side.
84 Chevy K-20
Old 12-21-2019, 05:29 PM   #6
MySons68C20
MySons68C20's Avatar
I run a wire with a small clamp from the battery positive direct to the HEI.
When you want to shut it off just disconnect at the battery.
MySons68C20 is offline   Reply With Quote
Old 12-21-2019, 05:30 PM   #7
Getter-Done
Actually the R terminal is to forward 12 volt positive to the coil when the starter is cranking. The S terminal is the one to hook the remote switch to to operate the solenoid.
Yes
Thanks for catching that
I was looking at the picture facing forward
and thinking about how I normally use a screwdriver
I will correct that in my 1st response
84 Chevy K-20
Old 12-21-2019, 05:55 PM   #8
HO455
HO455's Avatar
It's all good. Just trying to prevent confusion. I edited my reply also.
RIP Bob Parks.
Old 12-21-2019, 08:30 PM   #9
LockDoc
The Older Generation
LockDoc's Avatar
Positive battery cable to the large terminal on the starter solenoid.
Negative cable to any bolt on the engine block.
Remote starter button from the positive post on the battery to the "S" terminal on the starter solenoid.
Jumper wire from the positive post on the battery to the "BAT" terminal on the HEI.
Like mentioned above make sure the trans is in neutral or park.
Make sure that the oil pressure line is not disconnected or has a plug or cap on it.
Pour a little gas in the carb and push the remote starter button. It should fire right up.
Unhook HEI wire from the battery to kill the engine.
I know most of this was mentioned above but I figured having it all in one place he could print it out and have it in front of him.
LockDoc
Leon
Old 12-21-2019, 08:39 PM   #10
kingsolver72
10/30/19
kingsolver72's Avatar
Nice attention to the details Leon!!!
kingsolver72 is offline   Reply With Quote
Old 12-21-2019, 08:48 PM   #11
LockDoc
LockDoc's Avatar
Thanks Scott.
LockDoc
Leon
Old 12-21-2019, 09:19 PM   #12
Getter-Done
One more suggestion.
84 Chevy K-20
