Visor sticker oddity
Was in a salvage yard yesterday and this was on the visor. Not familiar with it.
Posted via Mobile Device |
Re: Visor sticker oddity
Mine still has the starting procedure sticker on it. Not the 2x4 sticker.
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet Mopar by Birth Chevy by Choice |
IF I am reading the SPID correctly, that one had the 350 diesel in it. Probably why the large starting procedure sticker. What clued me was the small square block between and above the speedo/fuel combo. On my CUCV, that has the Wait and Water in Fuel lights.
![]() Join Date: Jun 2009
Pretty sure that is a Doug Nash enterprises sticker. It looks like their logo
AZPartsLocators on Instagram 1972 Cheyenne Super Short Bed big block "Blackie" 1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog" 1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck. |
Dang, an add on 2 speed auxiliary gearbox would be cool, can you get under it to see if it's still there?
#7 | |
The lever on floor does not have a 2wd 4 hi lo on it. Just has the driveline symbol Did dne convert this to 4wd? Posted via Mobile Device |
my understanding is its a bolt on overdrive or dual range unit. made for 2 or 4 wheel drive.
Thats about all I know I found this http://www.dieselwarden.net/temp/usg...e%20manual.pdf Last edited by Danmcg; 01-02-2020 at 09:01 AM. |
looks like a 4wd shift handle....doesn't mean anything, but never seen a 4wd diesel.
Gentleman Jim Driver
NP203 transfer case conversion to part time.
https://67-72chevytrucks.com/vboard/...d.php?t=717134 This one has pdfs of a brochure: http://67-72chevytrucks.com/vboard/s...d.php?t=378406
Joe '75 GMC Gentleman Jim '84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter) '85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed |
Kinda makes sense now. Probly Doug Nash or whoever those abbreviations are for a part time kit for the 203.
Ok. Great info. I am working on a 1978 blazer so would be good to grab that stuff.
From what I can tell off of spid that truck that has it should not be 4x4. Thanks everyone Posted via Mobile Device |
SPID indicates the truck was originally 2wd.
(Model CC10903 would decode as a Chevy 2wd 1/2 ton lwb reg cab). K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
#14 | |
#15 |
Kinda stupid but I've seen it. Does the VIN on the spid sheet match the VIN of the truck? I found a truck in the junkyard that was a 1/2 ton. Opened glove box hoping the SPID was there, it was, and saw that is had 4.10s. Got all excited cause NEVER seen those gears in a half ton. Well, after I closed the glove box I saw it was a different color. Now in OP it looks like the door is the same color, but just thought id throw that out. But it doesn't make any sense why this truck would be converted to 4wd...
#16 |
I'm thinking it's C cab transplanted on a k frame
