Fender repair/replace
My front drivers fender is pushed up just behind the wheel. It looks like someone drove over a curb and it was crushed. Otherwise looks pretty good.
Would like to keep it but unsure which is going to be more work, hanging and aligning new fender or pulling, hammering and filling existing one.
1979 C-10 LWB |
78 Big10 454
![]() Join Date: Jul 2008
Re: Fender repair/replace
Pics would tell a better story, but from the info you provided, I'd opt for finding a decent fender rather than repair.
1978 Chevy SWB C-10 2WD 454/400 |
#3 | |
Attached is drivers and passengers fender. Drivers seems sort of roles under and flattened. Rest of the panel is fairly straight. Hate to lose this one because it looks original to the truck and doesn’t have much damage or rust. Passenger fender is from a donor and a little rusty where wheel well trim trapped dirt/water. Posted via Mobile Device |
![]() ![]() Join Date: May 2015
Doesn't look to bad...I'd try fixing it...what have you got to lose...
I'd try to fix it as is or just drive it
Robert Olson Transport
![]() Join Date: Oct 2002
thats fixable ive straightened a worse one
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
2nd the thought to try fixing it. Unless the truck is going to be a pretty pretty restoration, a few small imperfections probably isn't worth hassle of buying a repro fender and dealing with the fitment issues that often happen with the repros.
Expect the inner fender to need a little fixing as well. Pretty sure you can get replacement pieces that cover that area is it is a common rust out place. Backup plan in case the BFH route doesn't yield good enough results. |
you will never be happy with a aftermarket fender .
fix it for find a original used one .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
Sounds like I’m repairing....
Took the bed off and started doing some body work this weekend. It’s not going to be bad to fix. Fender is solid otherwise. Only trouble, other than bent/rusted hood is going to be the passenger bed side. Doesn’t look like a dent as much as the outer wall bows/flexes in just a bit but no obvious damage to outer or inner wall of the bed. Posted via Mobile Device |
Make sure you replace the hood hinges when you replace the hood!
Yep. Drivers side all bent and floppy.
