Old 01-03-2020, 10:35 AM   #1
SunSoaked
SunSoaked's Avatar
Anyone have a K series Longbed with a nv4500 swap?
I just want to know what rear driveshaft setup you're using.
One piece shaft or two?
My measurements indicate I'll need a 64 inch shaft which seems way too long. A two piece will require fabbing an x-member that I'd rather avoid.
SunSoaked is offline   Reply With Quote
Old 01-03-2020, 10:45 AM   #2
b454rat
Re: Anyone have a K series Longbed with a nv4500 swap?
When I had my 84 3/4 ton that had a one piece shaft. Was 400/208, if that helps any.
Old 01-03-2020, 11:12 AM   #3
sweetk30
sweetk30's Avatar
ran a 465/205 on a 135" c&c with a 1 piece shaft . over 60-65mph had a slight vibe .
the longer it gets tube length the more it wants to wobble . think of the old air plane kits we had as kids with the rubber band wind up for the prop . it would flex and bounce as it un wound .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 01-03-2020, 05:52 PM   #4
Richard
My first 72 a K20 LWB with a manual had a one piece driveshaft. Kept a one piece when I converted to an automatic. The drive shaft was massive compared to a car. Was at least 4"-5" in diameter.
Richard
Old 01-04-2020, 11:51 AM   #5
1976gmc20
Yep, same with my 1973
Only I ordered it with the automatic and within a few years wanted to convert it to manual. I actually did eventually, by trading it in for a K-10 with a manual.
Current/past Chevy/GMC trucks:
1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD
Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner
1976gmc20 is offline   Reply With Quote
Old 01-04-2020, 12:39 PM   #6
sweetk30
sweetk30's Avatar
fyi : check to see but i think aluminum shaft can be done in longer length . but thats if you have a slip yoke on the output as they dont do slip yoke aluminum last i knew of .
Old 01-04-2020, 02:51 PM   #7
kipps
A factory sm465 and np208 transfer case used a single piece driveshaft with a slip yoke.
The nv4500 appears to be about a half inch longer than the sm465, so the driveshaft length will be almost the same as the factory sm465 setup.
GM evidently didn't consider the length to be too great for a single-piece driveshaft.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
Old 01-05-2020, 04:15 PM   #8
K20super
Call Tom woods driveshaft company in Utah they built mine and it has no weights and is very well balanced. We build them at the shop I work at and the quality of the tube makes all the difference in the balance/ vibration.
K20super is offline   Reply With Quote
Old 01-05-2020, 06:49 PM   #9
SunSoaked
SunSoaked's Avatar
Yes, but.....my fixed output 205 is about 10 inches shorter than the 208 slip yoke.
Old 01-05-2020, 06:51 PM   #10
SunSoaked
SunSoaked's Avatar
Thanks sweet. I never thought about that. Learned something new.
Old 01-05-2020, 07:18 PM   #11
kipps
Oh.
But you never mentioned the transfer case swap. I was assuming a direct switch from sm465 to nv4500, with nothing else changing.
Old 01-05-2020, 07:35 PM   #12
SunSoaked
SunSoaked's Avatar
Oh.
True. Sorry about that. I appreciate your input.
Old 01-06-2020, 03:16 AM   #13
Richard
Not clear on what you are actually putting in. Personally I would avoid using a np208 slip yoke transfercase. If there is any sort of lift planned I would not recommend it.
Richard
Old 01-06-2020, 06:24 AM   #14
SunSoaked
SunSoaked's Avatar
Alright...let's start over:
85 Longbed K20.
Currently th400/np208. Slip yoke 1 piece shaft.
Going to install nv4500/np205. FIXED yoke.
Concern: Want to use a ONE PIECE shaft but....shaft length will be 63-64 inches!
Old 01-06-2020, 01:08 PM   #15
dieseldude4bt
I had a 1978 with SM465 and 205 and it had a one piece shaft fron the factory as does my 1993 dodge diesel G360 & 205.
63 k20 with cummins 4bt, owned sence 1982
dieseldude4bt is offline   Reply With Quote
Old 01-06-2020, 08:30 PM   #16
franken
I parted a 91 burb w/ an NV4500/NP205 and just measured the rear shaft at ~61" fully compressed. I'd guess the splined part is 6-7" so adding 2-3" or so for suspension travel gets to 63-64"
This wasn't a factory setup but it went down the road nice at 70.
Old 08-30-2020, 01:00 PM   #17
60sIron
60sIron's Avatar
My 69 K20 Suburban has a one piece DS. No issues. 465 with a 205.
60sIron is offline   Reply With Quote
