Old 01-05-2020, 11:28 PM   #51
Ford Assassin
Ford Assassin's Avatar
Re: Mongos 81 c30
Originally Posted by mongocanfly View Post
it is a 98 I believe...its the later one with the bolt on shift tower...but my bellhousing is advance adapters..with the clutch fork on the drivers side
Manual clutch conversion or still hydro?
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
Old 01-05-2020, 11:29 PM   #52
mongocanfly
mongocanfly's Avatar
Re: Mongos 81 c30
manual...on the IH I used the same bellhousing setup but used a hyd slave onit
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 01-15-2020, 11:23 AM   #53
Shifty One
Shifty One's Avatar
Re: Mongos 81 c30
Watching this build closely, looks great so far!
Old 01-15-2020, 08:05 PM   #54
mongocanfly
Re: Mongos 81 c30
well shifty....not much to watch..i built this truck over 10yrs ago...I will be pulling the bed off this summer to sandblast and repaint and redo the miserable bedliner job that's on it ...and also to fix the cab where some moron hit and run on me...it caved in the cab corner and the only way to fix it is remove the bed
thanks for looking though
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 01-26-2020, 01:17 AM   #55
mongocanfly
Re: Mongos 81 c30
had someone ask about the toolbox in the bed...its actually a tool drawer with dual 100# drawer slides on it....
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 03-04-2020, 03:12 PM   #56
mongocanfly
Re: Mongos 81 c30
Looking thru some old folders and finally found some pics of the C30 before I painted it..
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 03-04-2020, 03:17 PM   #57
mongocanfly
Re: Mongos 81 c30
And some of the body work needed...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 03-04-2020, 11:34 PM   #58
cochino12
It followed me home?
cochino12's Avatar
Re: Mongos 81 c30
Damn I love this truck, are you tired of it and want to sell it cheap? haha
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 03-05-2020, 12:01 AM   #59
mongocanfly
Re: Mongos 81 c30
Uuuhhhmmmmmmmm...nope...haha..
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 04-05-2020, 01:39 PM   #60
Ford Assassin
Re: Mongos 81 c30
Thanks skyphix!....
That 16 is only obtainable if you keep your foot out of it..haha
You didn't mention a cam swap, so I assume it's stock. I would love to get 16 from mine when done on a light foot on flat ground. The 454 TBI with the NV4500 has gotten 14 all highway unloaded. 8-9 towing our 30' 8,000lb travel trailer. 10-11 avg unloaded everyday driving. I put a super mild cam in my LQ4. Plus I have 3.73 gears.
Ran my truck across the scales today..it came in at 5680lb...
When I was registering my 3+3 dually I had to have it weighed on a certified scale. I was surprised it was only 5880 lbs. I figured 7000ish with the iron BBC. I am going to reweigh it after my LS turbo swap is all said and done.
Mine is the early for sure, but the outfit who performed the swap for the previous owner switched to the later model top plate with the bolt on shift tower. Which is good if I ever pull the trigger on a short throw shifter. The only one I have seen available for the GM version of the NV4500 is from Core....and that $300 pill is hard to swallow.
Check out my build thread, first build on a squarebody in almost 10 years and was a pain since I needed to run a stock LS ac compressor.
Cable
Old 04-07-2020, 11:37 PM   #61
mongocanfly
Re: Mongos 81 c30
correct..the engine is bone stock except for headers and a dyno tune
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 11-18-2021, 09:00 AM   #62
mongocanfly
Re: Mongos 81 c30
Did a little pulling upgrade to the C30..I added a under bed winch..
It's a superwinch 9000 that I had taking up space on the shop floor,so I put it to good use
I used a 1/2" plate that bolts to the frame to mount the winch and fairlead to,
and it was just right for fairlead to sit behind the tag
So I cut out the tag plate, welded a hinge to it ,and used a couple of magnets to hold it closed
The controls plug for the winch was broke, so while searching for a new plug, I found that I could use a wireless remote for the winch..bought a cheap one off Ebay and wired it in..best winch upgrade ever..!!
I also went ahead and wired in a new plug for the remote..for those just in case moments..
Ran the power wires up the frame rails to the battery, where I added a disconnect switch so no power is at the winch until needed..
I recently put it to use when I loaded the IH travelall on the trailer..
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 11-18-2021, 09:26 AM   #63
OutlawDrifter
Re: Mongos 81 c30
Great execution and addition!
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 11-18-2021, 05:21 PM   #64
mongocanfly
Re: Mongos 81 c30
Thanks outlaw!!!...
I wanted to get this knocked outta the way before I pull the bed off next summer
Still gotta fix the cab where I got hit and run on..and the bed has to come off to fix the cab dent..
and the bedliner that's on the bed is turning loose..
So the bed will get sandblasted,epoxy, and painted while its off..no more DIY roll-on bedliner
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 01-13-2022, 01:10 AM   #65
mongocanfly
Re: Mongos 81 c30
and a pic of the C30 in action..this is in Grand Junction Co....1500+ miles from Ala...did over 3000 miles on this trip..truck ran flawless and avg just over 13mpgs round trip
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 01-13-2022, 01:16 AM   #66
Ford Assassin
Re: Mongos 81 c30
Not bad at all!!
As much as I loved the 6.0/LS/turbo NV4500 setup in my C30....the Cummins mpg is insane.
Still haven't gotten used to the brick in the washing machine sound though. Lol
Cable
Old 01-13-2022, 08:47 AM   #67
OutlawDrifter
Re: Mongos 81 c30
That's not bad at all, especially pulling that aerodynamic binder!
1991 Z/28, 6.0L/T56
Old 01-13-2022, 12:06 PM   #68
mongocanfly
Re: Mongos 81 c30
Yeah was really thinking diesel swap way back then, but then I started pricing engines, changed my mind quick...
And as far as pulling the "IH brick", most of the time I had to look in the mirrors so I'd know it was still back there, even when I went thru the cyclotyphoonado in Arkansas, the crosswinds had little effect..
But it did not like pulling Vail pass on i70...about 35mph is all I could get at those elevations going up some of those hills
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 01-13-2022, 12:15 PM   #69
OutlawDrifter
Re: Mongos 81 c30
And as far as pulling the "IH brick", most of the time I had to look in the mirrors so I'd know it was still back there, even when I went thru the cylcotyphoonado in Arkansas, the crosswinds had little effect..
The air gets pretty thin up there, you either need A LOT of cubic inches or some forced atmosphere!
1991 Z/28, 6.0L/T56
Old 07-27-2022, 04:03 PM   #70
mongocanfly
Re: Mongos 81 c30
I decided to replace my 40+yr old shocks.. been awhile since I've bought shocks, WOW, they sure have got pricey.. went with bilstein 4600, the old orig shocks I pulled off had no rebound left
No time to drive it yet to see if it makes a difference, the rubber bushing in the old ones was deteriorated and I noticed I was having front wheel bounce issues..
I also noticed some nice flat spot cupping on the fronts, so I may have to get them trued up..
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 08-18-2022, 04:20 PM   #71
mongocanfly
Re: Mongos 81 c30
just a update..
all i can say is WOW ,what a difference the new shocks made..
i took the truck for a 40mph drive across the hay field..very very smooth..
before your head would hit the cab roof doing about 15mph
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 08-18-2022, 05:15 PM   #72
OutlawDrifter
Re: Mongos 81 c30
Strange what we can get used to!
1991 Z/28, 6.0L/T56
