Old 01-03-2020, 02:51 AM   #1
rod1701
rod1701's Avatar
Fender repair/replace
My front drivers fender is pushed up just behind the wheel. It looks like someone drove over a curb and it was crushed. Otherwise looks pretty good.
Would like to keep it but unsure which is going to be more work, hanging and aligning new fender or pulling, hammering and filling existing one.
1979 C-10 LWB
rod1701 is offline   Reply With Quote
Old 01-03-2020, 03:33 AM   #2
78 Big10 454
78 Big10 454
78 Big10 454's Avatar
Re: Fender repair/replace
Pics would tell a better story, but from the info you provided, I'd opt for finding a decent fender rather than repair.
1978 Chevy SWB C-10 2WD 454/400
78 Big10 454 is offline   Reply With Quote
Old 01-03-2020, 03:41 AM   #3
rod1701
rod1701's Avatar
Sorry about that. Hopefully this will give an idea.
Attached is drivers and passengers fender. Drivers seems sort of roles under and flattened. Rest of the panel is fairly straight. Hate to lose this one because it looks original to the truck and doesn’t have much damage or rust. Passenger fender is from a donor and a little rusty where wheel well trim trapped dirt/water.
Old 01-03-2020, 09:26 AM   #4
mongocanfly
mongocanfly's Avatar
Doesn't look to bad...I'd try fixing it...what have you got to lose...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 01-03-2020, 12:14 PM   #5
xrcr
I'd try to fix it as is or just drive it
xrcr is offline   Reply With Quote
Old 01-03-2020, 06:55 PM   #6
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
thats fixable ive straightened a worse one
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 01-04-2020, 09:54 PM   #7
Dead Parrot
2nd the thought to try fixing it. Unless the truck is going to be a pretty pretty restoration, a few small imperfections probably isn't worth hassle of buying a repro fender and dealing with the fitment issues that often happen with the repros.
Expect the inner fender to need a little fixing as well.
Pretty sure you can get replacement pieces that cover that area is it is a common rust out place. Backup plan in case the BFH route doesn't yield good enough results.
Dead Parrot is offline   Reply With Quote
Old 01-05-2020, 10:32 AM   #8
sweetk30
sweetk30's Avatar
you will never be happy with a aftermarket fender .
fix it for find a original used one .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 01-05-2020, 11:42 PM   #9
rod1701
rod1701's Avatar
Sounds like I’m repairing....
Took the bed off and started doing some body work this weekend. It’s not going to be bad to fix. Fender is solid otherwise.
Only trouble, other than bent/rusted hood is going to be the passenger bed side. Doesn’t look like a dent as much as the outer wall bows/flexes in just a bit but no obvious damage to outer or inner wall of the bed.
Old 01-06-2020, 07:09 PM   #10
Big Chip
Big Chip's Avatar
Make sure you replace the hood hinges when you replace the hood!
Big Chip is offline   Reply With Quote
Old 01-06-2020, 08:29 PM   #11
rod1701
rod1701's Avatar
Yep. Drivers side all bent and floppy.
