04-09-2018, 08:06 PM | #101 |
Re: "its all about ol' black"
The Maximizer has been in for a little while now and is virtually unnoticeable with hubs locked all the time and not powered.
When being powered the front is very easy to steer and seems to be sure footed without the strain of constantly darting back and fourth on snow covered roads like the Locker would exhibit. When getting wood out of bush and such its turns very easy at slow speeds without unlocking rear drive or front drive to turn sharp. My thumbs up for this very streetable and affordable differential. I will keep you posted on longevity.
100:1 low gear! |
04-16-2019, 11:32 PM | #102 |
Going to use your NV4500 bellhousing idea on my trans swap.
Thanks for the photos |
04-19-2019, 01:11 PM | #103 |
44th Miss Inf- no problem , thats why I post this stuff to help other people .
Ol' Black was down the past couple of weeks had to order new rebuilt tbi engine from ATK as the high mile one in it was starting to make some noise down low. Back up and running again love my differentials and no issues. Also the motor has a 3 year warranty!
100:1 low gear! |
07-06-2019, 05:39 PM | #104 |
very nice truck. You have given me some ideas for my 72...
1972 Chevy C10 400sbc 4sp Matthew 4:19 And he saith unto them, Follow me, and I will make you fishers of men. |
01-09-2020, 11:48 AM | #105 |
OL' Black gets some updates-
Got some union pacific sequential LED taillights to replace the badly sun faded ones, straight bolt on and plug in... very nice! Decided to get the LMC 81-87 door panels I have always wanted. I just had to change the inside handle from the 77-80 and winder.
100:1 low gear! |
01-09-2020, 12:01 PM | #106 |
While I was ordering door panels I got a new bench seat cover (Vinyl) because I am always spilling coffee LOL!
Already swapped to an 81-87 seat some time ago. The foam was pretty good shape so it was reused , but I added a 3" memory foam mattress pad to the bottom seat between the springs and the foam for a comfort boost. The cover came with hog rings and pliers (bonus)
100:1 low gear! |
01-09-2020, 12:15 PM | #107 |
To tighten the springs up in the seat suspension I bent up the tabs added zip ties under to make thicker then bent them back down.
Quick paint then put the 'socks on the rooster' I think it turned out alright .
100:1 low gear! |
01-10-2020, 11:32 AM | #108 |
Excellent seat re-do! Looks fresh but right at home in that cab too.
04-12-2021, 05:41 AM | #109 |
Well my r/s led tail light got moisture in it and was acting up after 1 year so I emailed United Pacific and they instructed me to go through my ebay seller where I bought it from and no surprise they are not on ebay anymore.
So I shelled out another $150 CND for a replacement from somewhere else which wont happen again! So much for so called epoxy sealed.
100:1 low gear! |
04-12-2021, 05:57 AM | #110 |
Got some H4 headlights from amazon to replace my candles in glass lol. I think it ads a cool look also.
They fit in but the rubber boot around the terminals is too big to fit in the headlight bucket without modifying the bucket so I chose to leave them off, also I cut thick O-rings in half and installed them between the headlight and hold down ring at the three attaching screws because they are a slightly smaller diameter. They are Brighter but I am going to add relays for full improvement soon .
100:1 low gear! |
06-08-2021, 06:00 AM | #111 |
A couple of updates -
I got a new back window graphic , I think it suits OL' Black well! Some parts from LMc A relay harness and printed circuit . The printed circuit is a good quality and straight forward swap. Also added the 5 backlit LED bulbs to my cluster, Brighter! The relay harness was only long enough to run in the position I installed and the eyelets on the ground wires were too small for the factory ground bolts other than that all plug and play . Now , just to stay up late enough to see how bright my headlights actually are...
100:1 low gear! Last edited by doubleclucker; 06-09-2021 at 07:22 AM. |
06-08-2021, 06:10 AM | #112 |
A couple more pics...
100:1 low gear! |
11-13-2022, 06:50 AM | #113 |
UPDATE for 2022-Still going daily driver workhorse ,no issues with the differentials bought some crane kingpin spring bushing replacement to try out will post when installing.
100:1 low gear! Last edited by doubleclucker; 11-13-2022 at 06:56 AM. |
11-20-2022, 11:15 AM | #114 |
Id like to know how those LMC interior door panels hold up, cause they are painted according to LMC..... paint chip off?
'81 K20 Silverado , '99 Dodge Cummins 4x4, '05 Dodge Cummins 4x4, Pinstriping-Lettering-Specialty Painting |
11-20-2022, 04:25 PM | #115 | |
. These panels seem and feel like cheap crap , but I love the look (style) of them.
100:1 low gear! |
11-20-2022, 04:59 PM | #116 |
I need head light bezels and grill for my '81 k20.... Im wondering who has the best quality ones and who has the cheap crap Ive been to the Truck and Car Shop of Orange in Ca. I wonder if their stuff is better than LMC.... Bought a item from Brothers too, it was a POS
11-26-2022, 05:23 PM | #117 |
Really cool truck. Your doing some good work!
