Old 12-14-2019, 10:55 AM   #51
Cohi
Cohi's Avatar
Re: COHI's 1966 Longbed
Weld through primer was sprayed on the frame rail and the back of the bracket. The bolts shown are just run through the holes to hang it in place without the nuts. Everything fit perfect. A c-clamp was applied and everything was mig welded up.
Denver/Big Island -- Instagram: Slammed64c10
'46 Fleetmaster Coupe
'66 C10 w/355sb/700r on Ridetech Air Ride
'64 C10 on GSI Bagged Chassis, 408 stroker w/twin 64's - in progress
Cohi is offline   Reply With Quote
Old 12-14-2019, 11:00 AM   #52
Cohi
Cohi's Avatar
I'd recommend running a tap through the holes on the gear box before hanging it. Makes it a lot easier to thread those bolts while holding a heavy box above your head. Capt Fab includes Grade 8 bolts with his kit, and you dont have to drill any holes out on the gear box itself. It mounts like it was designed to mount.
You can see that I still have to cut that shaft back further to get everything to fit.
If you're looking at the suspension setup, its Ridetech's stuff, new upper/lower control arms, drop spindle, bag, {HEAVY} duty sway bar, adjustable shock and their e-level unit. Disc brakes were from CPP.
Old 12-14-2019, 08:36 PM   #53
Cohi
Cohi's Avatar
New moog pitman, rag and Capt Fab's adapter on. Need to weld it to the shaft, cross drill and bolt tomorrow. Stock replacement Moog K14 idler on the other end. The Centerlink runs about 1/4" from the cross member with the wheels pointed straight ahead. I was concerned about rubbing but its thankfully not an issue.
Old 12-14-2019, 08:38 PM   #54
Cohi
Cohi's Avatar
torqued at 175 per manufacturer. the nut from the manual box fit fine.
Old 12-14-2019, 09:13 PM   #55
Cohi
Cohi's Avatar
Originally Posted by roll_the_dice View Post
Looking good...Great job...maybe I missed it, but are you going to do a repaint or just keep the green and clean it up?
Thanks!
I'll fix the floors and get the interior upholstery finished up by spring-ish. Exterior will stay the same for the time being. Prolly start body work in a year or two.. maybe three.
Old 12-14-2019, 09:17 PM   #56
Cohi
Cohi's Avatar
Added an an Autometer O2 sensor on the left back that feeds this AFR gauge. Makes jetting a Holley a LOT easier. I'm in Denver (for now) so this thing got jetted down considerably to keep it from running pig rich.
Sry for the weird angle on the pic.
Old 12-15-2019, 01:36 PM   #57
Cohi
Cohi's Avatar
Shaft tacked and cross drilled. 1/4” grade 8 x2.
Old 12-23-2019, 08:59 AM   #58
Cohi
Cohi's Avatar
Finally got around to widening the wheel tubs, here a few start pics. 5.25 inches. the bendy pieces on each end will be grafted in.
Old 01-09-2020, 04:26 PM   #59
Cohi
Cohi's Avatar
rough body work and epoxy for now.
Old 01-09-2020, 04:46 PM   #60
62 short step
62 short step's Avatar
Very nice!
www.louisianaclassictruckclub.com
1965 c-10
86 chevy c/k 20
62 short step is offline   Reply With Quote
Old 01-12-2020, 09:54 AM   #61
Cohi
Cohi's Avatar
Originally Posted by 62 short step View Post
Very nice!
Thanks Bud! No more rocks and water flying up into the bed from now on
Old 01-14-2020, 05:04 PM   #62
made2drag
made2drag's Avatar
Looks good so far!
made2drag is offline   Reply With Quote
Old 01-18-2020, 08:59 AM   #63
Cohi
Cohi's Avatar
Originally Posted by made2drag View Post
Looks good so far!
Thank you Sir!
Old 05-28-2020, 12:20 PM   #64
Cohi
Cohi's Avatar
700R4 running warm at sustained freeway speeds so I added a B&M (#70266) plate style supercooler. Probably overkill for what I needed but it did the job quickly. Mounting straps are aluminum. There's standoff space between the A/C condensor and no clearance issues with the grill. It's still plumbed through the radiator. Current thermostat is a 195 which i put in for winter, but may drop back to a 180 during Denver's summer.
Old 05-28-2020, 01:57 PM   #65
pdxhall
pdxhall's Avatar
I just looked through your build. Great work! It's good to see another long bed.
I added an additional BM trans cooler through my 700r4 besides the internal radiator cooler. it works great, even in this southern AZ heat.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 06-04-2020, 07:19 AM   #66
Cohi
Cohi's Avatar
Thanks! I lived in PHX in 90 and was rolling in a 54 ford pkup in primer black with no a/c. Trans cooler worked good though
Old 11-13-2023, 07:22 AM   #67
Cohi
Cohi's Avatar
Red face Re: COHI's 1966 Longbed
Well... she ran and rode pretty good on the Ridetech system, Blueprint 355 and Bowtie 700R4 (I did fry one 700r4 when the TV cable went out of adjustment unnoticed).
Presently waiting (12 months) on a GSI air ride chassis, new LS drivetrain prepped and ready to install. Before it comes to me in Colorado, the chassis will pay a visit to Arizona High Test for stainless brake and air line plumbing. Hoping to finally get the chassis by Dec/Jan - then lots to do over the winter.
Old 05-28-2025, 09:11 PM   #68
Cohi
Cohi's Avatar
long time since an update and many things have changed. Rather than tear into the running 66, I gifted it to my daughter - because she's cool as heck.
Here's the new build quite a ways along: 64 lb on a chassis with an LS.
