Old 01-17-2020, 02:31 PM   #1
ohboy321
ohboy321's Avatar
4x4 Radiator Shroud Question
Did all 67-72 4x4 trucks have the 4x4 specific radiator shroud?
My 67 with a 327 currently has the shorter fan shroud. I haven't had any overheating issues in the few years I've owned it, but if it is supposed to have one I may work on doing that to prevent issues in the future.
When looking at my current shroud, I can see where having a deeper (by 3"?) one would work better.
Thanks,
Steve/NH
ohboy321 is offline   Reply With Quote
Old 01-17-2020, 04:38 PM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: 4x4 Radiator Shroud Question
Can't say for sure, but I bet they all came with the deeper shroud. For maximum efficiency, the fan blades should be right at the end of the shroud. I have read half-in and half-out is best, or just inside the end of the shroud. If yours is 3" away, it can't be pulling all its air through the radiator as it should.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 01-20-2020, 09:59 AM   #3
ohboy321
ohboy321's Avatar
The shroud and radiator are currently out of the truck, but it may be even more than 3 inches between the fan and the outside edge of the shroud.
I have read that the 4x4 motors were set back several inches compared to the 2WD trucks, which explains the different shrouds being used. So now I am thinking that all 4x4s would have used them.
My truck was made up from both 4x4 and 2WD trucks, so that would explain how it ended up with the shorter shroud.
As I mentioned, I haven't had any overheating issues yet, but I haven't sat in any long summer traffic backups or moved any heavy loads either.
Steve/NH
1967 K10 327 Short Bed Stepside
Old 01-22-2020, 10:58 PM   #4
jamie72
jamie72's Avatar
the motor on 4x4s is farther back than 2x4s, so they do have a specific shroud just for 4x4s.
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 01-22-2020, 11:59 PM   #5
646870SS
Here is the NOS one I put on my truck (showing sticker) - I can take a picture of the installed shroud (fan side) and check the distance on my '72 4x4.
646870SS is offline   Reply With Quote
Old 01-23-2020, 03:00 PM   #6
ohboy321
ohboy321's Avatar
Thanks for the picture of the label 646870SS, with the part number I did a little more research and that would be the correct shroud for my 67. I was able to verify it on GMPartsWiki here: http://www.gmpartswiki.com/getpage?pageid=21326 (starts at bottom of page).
Below is a picture of what I have now, and based on comments it is clear that I need the deeper shroud. One of the tabs is broken and I was going to repair it before putting it back in, but now I think the best thing to do is track down the OEM part.
Thanks to all for the help.
Steve/NH
Old 01-23-2020, 04:04 PM   #7
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Yep, you sure do..... that appears to be a shroud for a 2WD truck.
Have you considered also adding a clutch fan? Well worth it IMO. If you're interested you can search for more info, or if you like I can pass along a few details for you.
- Mike -
RIP El Jay
Old 01-23-2020, 05:54 PM   #8
646870SS
Here are the pics of mine. It is an original 4x4 truck with the NOS fan shroud. The one photo looks deceiving - the fan is in the shroud about 3/4" total so it is tucked in but this way it draws air with all that room in the front - the fan being so far back - it doesn't stick out from shroud. Hope this helps. I am not running a clutch fan, just the original one and it stays very cool. It is an air conditioning truck as well. Also running the original fan spacer - I think it is an 1-3/4".
Old 01-23-2020, 10:49 PM   #9
jamie72
jamie72's Avatar
lmc sells them, if you were closer i got 2 extras, but shipping would kill the deal.
jamie72
member #807
www.antlertalk.com
Old 01-24-2020, 09:17 PM   #10
ohboy321
ohboy321's Avatar
Those pictures are great 646870SS. I'm now surprised I haven't had any issues with overheating with the wrong shroud in place.
Stocker, no, I haven't considered a clutch fan for my truck, although I am familiar with the advantages. I have already media blasted and painted the one I have, so for now I will just concentrate on getting the correct shroud.
I'll be posting a WTB as soon.
Steve/NH
Old 01-27-2020, 12:40 PM   #11
tim_mc
tim_mc's Avatar
I used a 4/4 shroud since my V8 is mounted in the 2WD straight 6/4x4 SBC location. My Derale 17118 18" 6-blade clutch fan fits perfectly. Shroud is LMC P/N 32-2826.
1967 C20, 350 SBC w/Comp roller cam, 700R4 w/3.42 posi, PS, 4-wheel PDB, Old Air AC & GM Tilt column.
tim_mc is offline   Reply With Quote
Old 01-27-2020, 10:17 PM   #12
jmader
jmader's Avatar
How is the quality of the ones from LMC? I have an aftermarket from classic industries I don’t really care for. It’s more of a hard fiberglass than plastic.
1949 Chevy 3100 Five Window
1964 Chevy C10 Lambrecht Auction project
1967 Chevy SWB K10
1967 GMC K15 Project
Build thread-
http://67-72chevytrucks.com/vboard/s...72#post6502772
1968 Chevy Anniversary K10
1991 K5 4" Lift 35's (the wife's toy)
jmader is offline   Reply With Quote
Old 01-28-2020, 09:04 AM   #13
tim_mc
tim_mc's Avatar
I'm happy with my LMC shroud. The mounting holes lined up well, and the plastic is rigid enough to keep it's shape.
Old 03-02-2025, 10:37 AM   #14
1970cstblazer
1970cstblazer's Avatar
Question Re: 4x4 Radiator Shroud Question
Do you have more pics of the LMC 4x4 fan shroud?
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze poly, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion..
2017 Sierra 1500 SLT 4WD, Black, 46k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 67k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 03-02-2025, 07:37 PM   #15
best view
I’ve bought two from lmc they are the balls
best view is offline   Reply With Quote
Old 03-02-2025, 09:46 PM   #16
tim_mc
tim_mc's Avatar
Sure, here are a couple of pics.
Old 03-02-2025, 10:13 PM   #17
truckster
truckster's Avatar
Your location probably has a lot to do with that.
I used the LMC shroud as the basis for a custom installation (I have a 5.7 Vortec in mine). The quality is very good.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 03-03-2025, 08:44 AM   #18
1970cstblazer
Thumbs up Re: 4x4 Radiator Shroud Question
Thank you for the photos and the feedback.
