#253 |
Moderator
![]() ![]() Join Date: Aug 2011
Re: 66 k20
The good thing about that greasy mess is, it's well preserved.
#254 | |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Re: 66 k20
#255 |
![]() Join Date: Oct 2012
Re: 66 k20
Thanks. I had them mix Nissan sunlit sand. Seems to be almost a dead on match.
#258 |
Re: 66 k20
I tried to make my own “hot tank” using a trash can and a turkey fryer. It worked fairly well considering all i had was Dawn to add to the water. Next time I will try simple green which is what they were using in the video I saw for this. It certainly didn’t boil the paint off but it did get all the gunk out of the inside.
#259 |
Re: 66 k20
Pretty much got it back together. There is some side to side slop with the gears and spacer on the idler shaft that I posted a question about on the 4x4 forum.
#260 |
![]() Join Date: Apr 2000
Re: 66 k20
i`m a 67-72 guy but i really like this truck,keep at it.
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
#261 |
Re: 66 k20
Chasing down vibrations I pulled the rear driveshaft and took it to the machine shop in town. The slip yoke and splines are wore out, he thought it was also too small in diameter and too short by the spline engagement. He built me a new one, not cheap by any means but wow. That’s good work.
#262 |
Re: 66 k20
Finally got some custom make front brake hoses to get rid of the cobbled up adapters I had. Thank you Les for the referral he was great to deal with.
While I was at it I also took the time to upgrade to a dual reservoir master. |
#263 |
Re: 66 k20
I also changed my mind about tire and wheel combo again. Ordered these cragars from summit and sourced tires locally. Wheels are 8 lug 15x10 Cragar nomad II, tires 35x12.50-15 Hercules Terra Trac
#264 |
![]() ![]() ![]() Join Date: Jan 2018
Re: 66 k20
The truck is looking great! I like the new wheels and tires
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
#265 |
Re: 66 k20
Looking good, how did the drive shaft help your vibration? Did you get your front springs and shackles replaced?
#267 | |
Re: 66 k20
No, I haven't got to the front springs yet. I've got an old slide in camper I'm trying to get useable for a camping trip next month so it's getting all my attention for now. |
#268 |
Re: 66 k20
Next upgrade power steering to turn those big tires. Did you still have the 7.50 16 tires, was wondering the actual height of those tires compredto new ones you have now.
#269 |
Re: 66 k20
I sold them fairly quickly much to my surprise. They were ~ 32”.
#270 |
![]() Join Date: Apr 2009
Re: 66 k20
Getting Rare And Less My Out There. My 66 GMC
1966 GMC K25 V6 351E Original Utility Truck 2000 C3500 Hot Rod Utility Truck 2003 ROAD KING 100th 124ci 6 Speed 145CI M/P Pro Street FXR 2002 FXDP 2007 2500HD DURAMAX. DD Studio Teamsters / Mechanic Retired GM Master Tech 20 Years Retired Ford Tech 15 Years |
#271 |
Re: 66 k20
How's life treating you and your truck these days?
#272 |
![]() Join Date: Oct 2013
Re: 66 k20
Lots of great progress, and shared information.
Any new updates? Les |
