Old 01-18-2020, 05:55 PM   #1
Adrianjc
Dropping 69 c10 3/5
I’ve been wanting to drop my truck 3 in the front 5 in the rear , the question is would I need to do a C notch ? I’m really trying to avoid doing that .
Adrianjc is offline   Reply With Quote
Old 01-18-2020, 07:44 PM   #2
Abomb
Re: Dropping 69 c10 3/5
No, it’ll be fine unless you haul a bunch of weight...mine is dropped 3 and 5 with springs only.
Abomb is offline   Reply With Quote
Old 01-18-2020, 07:54 PM   #3
Adrianjc
Awesome thank you !
Your Truck looks great !
Old 01-18-2020, 09:59 PM   #4
gphillips72wagon
I purchased a C10 with a similar drop without the C-notch in the frame. It rode terrible because of the lack of suspension travel. I did a bolt-in C-notch kit (also welded it) and the difference in ride quality was incredible!
Gordon
Columbus, OH
gphillips72wagon is offline   Reply With Quote
Old 01-20-2020, 10:26 AM   #5
68Stepbed
68Stepbed's Avatar
This was how my truck sat with a 4.5 front, 6.75 rear drop. No c-notch, and rarely had bottoming out issues.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 01-20-2020, 02:50 PM   #6
TruDom
i have the 4/6 drop from ECE. bottom out the rear every now and then but not enough to c-notch it. I recommend ECE.
i've heard other people have problems using springs/kits from other brands though. (they sit lower)
i dont see the downside of doing the drop, then c-notching if you have problems.
TruDom is offline   Reply With Quote
Old 01-20-2020, 04:49 PM   #7
typerr
I'm at about 3.5/5 with my drop. I bought a bolt-in c-notch kit but never installed it. I've loaded up the bed with junk to haul to the dump and still have yet to bottom out. I think I have about 3" between the axle and frame which seems to be plenty if you are careful.
typerr is offline   Reply With Quote
Old 01-20-2020, 07:27 PM   #8
3767
Ive had a 3/5 drop and this is what I learned from it. If u have the trailing arm set up...use drop blocks at least 4 part of it. I used just the drop springs and it wasnt that great of a ride. Get quality shocks. Dont settle for the cheaper sets. Your back will thank u. Use shock relocation kits. This will give more of the stock travel. The drop shocks are stiff due to limited travel and it shows when u drive it. Measure down with a ruler and u can c just how close the bump stops get to the rear end . U can go up 2 7 inches of drop but u may want to trim the factory stops for more clearance. Where u live has alot 2 do with it 2. If the roads u travel are smooth it's not as noticeable but get on a ruff road and it wont take long to find out just how good your kit is.
Take Matt's blue truck for a good example. It has a well made system under it. So it gives a good ride and good handling as well. Good luck in what ever system u choose.
3767 is offline   Reply With Quote
Old 01-20-2020, 10:52 PM   #9
66clow
66clow's Avatar
3 5 was no problem without the notch. Rode for years that way until I went to 5 7 and put in the notch.
66clow is offline   Reply With Quote
Old 01-21-2020, 04:06 AM   #10
spitfire980
spitfire980's Avatar
Are the numbers you guys are posting including drop spindles or stock spindles?
Iv got CPP 2 inch drop spindles but from what iv read, its actually 2.5 inch drop so id like to know so I can see what mines would look like
spitfire980 is offline   Reply With Quote
Old 01-21-2020, 10:04 AM   #11
66clow
66clow's Avatar
Mine was just springs, but if you can do drop spindles do that
Old 01-21-2020, 04:58 PM   #12
3767
2.5 drop spindle with 1 inch drop spring up front. 5 inch drop springs out back.
Old 01-23-2020, 05:19 PM   #13
mkmc69
mkmc69's Avatar
That is pretty much how I'm going to set mine up. The only difference will be 4 inch drop springs with a 1 inch block in the back. Do you have a picture of how it sits? Rides ok?
mkmc69 is offline   Reply With Quote
Old 01-23-2020, 07:19 PM   #14
3767
I didnt like the ride but....the kit I had used drop shocks. They were stiff and that caused the ride to b somewhat ruff depending on the rd and how smooth it was. If u get better and longer travel shocks it would b fine. Yes I have a pic but I cant get it to upload 4 what ever reason. I will try again but if it doesnt load,shoot me ur email and I will send it that way. Ive got it apart now rebuilding the whole thing
Old 01-23-2020, 07:42 PM   #15
blenon
Just redid the springs and added spindles. Rear 5" Belltech springs. Front 1" Belltech springs and 3" drop spindles. I think I am going to install the 2" drop springs in the front to get the front tire wheel well gap a bit smaller.
Nitro drop 2 shocks, relocation for rear shocks and no c-notch.
blenon is offline   Reply With Quote
Old 01-25-2020, 10:24 PM   #16
Adrianjc
Lowered the truck looks and rides good !
Thank you all for the advice
Old 01-26-2020, 11:22 AM   #17
Boog
laying low
Boog's Avatar
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
