Old 01-20-2020, 05:25 PM   #1
Jack15T
71 K20, Eaton H052
Hi folks, My 71 K20 has an open Eaton H052 rear Dif. I would like to convert it to a locker, either manual or automatic. I called Eaton and they said unofficialy I could use a Detroit Locker number 225S10. I need 30 spline axles for the Detroit. Has anybody done this conversion and know of an axle that would work? The axle shaft diameter is 1.5 in. I don't have a length. Any and all suggestions are welcome. Thanks, Jack
Jack15T is offline   Reply With Quote
Old 01-20-2020, 06:07 PM   #2
mongocanfly
mongocanfly's Avatar
Re: 71 K20, Eaton H052
personally..id just get a locking 14b and swap it out...not sure on the widths though..but if possible itll be much cheaper than trying to do anything with the ho52
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 01-20-2020, 06:18 PM   #3
Jack15T
Thanks Greg, I'll look into it.
Old 01-20-2020, 07:29 PM   #4
sweetk30
sweetk30's Avatar
been told and read the detroit form a 14ff will swap inside the open carrier in place of the spider gears . then the 14ff shafts the correct length will swap over also . then you have a eaton ho with a locker .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 01-20-2020, 08:09 PM   #5
Jack15T
That would be pretty nice. Thanks for the tip.
Old 01-20-2020, 08:50 PM   #6
sweetk30
sweetk30's Avatar
i might be a bit off on info for the 52 .
but here is a MEGA thread on ho72 stuff https://www.pirate4x4.com/forum/chev...aton-h072.html
Old 01-20-2020, 09:18 PM   #7
Jack15T
Thanks, I'll take a look at it.
Old 01-20-2020, 09:58 PM   #8
Mike C
Mike C's Avatar
The HO52/72 is the grandfather of the 14 bolt. You can use the 14 bolt detroit locker along with the shafts from the 14 bolt to make that work.
Measure your original axles and find a set from a 14FF that are the same length.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 01-20-2020, 10:23 PM   #9
Jack15T
Thanks Mike, I'll take a look at it. Jack
Old 01-20-2020, 10:42 PM   #10
dozerbill72
dozerbill72's Avatar
I have used a 14 bolt locker and axles twice in Eatons. The 14's that I used I had to cut about a quarter of an inch off both axle shafts to get them to seat at the hubs. I think they where 1 ton single wheel versions but don't know for sure. It's not cheap, but it is a lot easier than trying to find a factory locker for an Eaton thats not cheap either if you find one.
dozerbill72 is offline   Reply With Quote
Old 01-20-2020, 11:08 PM   #11
Jack15T
Thanks Dozer, That would work.
Old 01-22-2020, 01:09 AM   #12
Short 3/4
Have you tried looking for used? Lots of C 20 and 30's came with NoSpin option, which is what factory called a Detroit Locker. Also Eaton sold them to the aftermarket as a Detroit until the mid 80's (I think I bought one of the last new ones in about '85). My point being there are a lot of them out there, and is an easy conversion with the drop out carrier. Even if you reuse your R&P would still be easier than messing with custom axles I would think. FYI this is the only traction upgrade ever made for these axles. For some reason the factory never offered them on the K trucks, But I can tell you they are a great addition to one.
For what its worth, while you have that pumpkin out you can weld a pipe bung in the housing for a drain plug. The one thing Chevy forgot. With the occasional oil change, that Eaton will outlive you.
Good luck with the project however you go.
Tom
65 short stepside K10
292-SM420-T221
8 lug closed D44 front
NoSpin HO72 4.10 rear
Short 3/4 is offline   Reply With Quote
Old 01-22-2020, 10:31 PM   #13
Mike C
Mike C's Avatar
You can buy aftermarket cut to fit axles if you don't have any luck finding a donor. They come with a LONG spline so you can get it down for custom/special applications.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 01-24-2020, 02:56 PM   #14
Jack15T
Hey Guys , thanks for all the info. I did find a brand new locker NOS that was the original Detroit locker for the HO52 rear axle. It's complete except for one spring. The locker number is 2426042. Anybody have a spring that would fit? Dimensions are: Spring wire is .150, ID is 1.950, OD is 2.250, Height is 2.400 Thanks, Jack
Old 01-29-2020, 11:33 AM   #15
Jack15T
Hey Guys, It turns out that the number (2426042) is actually the number on the tag attached to the remaining spring in the Detroit Locker assembly. I still need the spring for the other side to make this locker work. I haven’t had any luck with Eaton or the usual suspects. Does anybody have a spring from that generation or know what the part number was for the entire locker assembly? Thanks, Jack
Old 01-30-2020, 02:39 AM   #16
Short 3/4
Should be a model KS-10.
Good Luck with the search,
Tom
292-SM420-T221
Old 01-30-2020, 06:27 PM   #17
sweetk30
sweetk30's Avatar
what about a set of springs off a 14ff detroit ?
Old 01-31-2020, 08:09 PM   #18
Jack15T
Thanks for the Part number Tom. That's a big help. SweetK30-Good thought on trying springs from a 14FF. I'll look into it. Jack
