Old 06-16-2004, 02:42 PM   #1
AirMale
AirMale's Avatar
Need some help installing front airbags
I bought the upper plates, bags and cups from Jason @*****************. Now I need some pics to make sense of how it all goes in. I would love to see some pics of this if anyone can post some. Plus, do I run a 90° fitting off the top of the bag or not? I got everthing except the fittings and airine for $215 to my door. The plates and cups are beautiful and the bags are 2B7s from Airlift. I am gonna run it to a pair of schrader valves and pump them up at the gas station until I get the four link done. Then I will get some advice on what would be a good control system. I can handle this install better if I can break it up into smaller jobs. Thanx in advance, Jay
86 SWB 9.0 LITER
T-400-OD 4.11 eaton-4/5 drop
Best 1/4 12.51 @112mph no traction
AirMale is offline   Reply With Quote
Old 06-16-2004, 02:52 PM   #2
Izzy
Trucker.
Izzy's Avatar
I'll post a pic of how they were mounted on my 83 tonight.
I used a straight fitting off the top of the bag and ran the line through a hole in the spring pocket(grommeted) down the frame.
The plate bolts to the lip on the spring pocket with 4 nuts/bolts. The lower cup stays in the LCA pocket just like the coil.
Izzy is offline   Reply With Quote
Old 06-16-2004, 03:10 PM   #3
AirMale
AirMale's Avatar
Thanks Izzy. I was reading the tech section on the Airlift site and they offer no illustrations but say to drill a hole and run a 90 near the brake line mount on the frame. It also says something about a jounce thingy that has to be removed, I sound dumb now huh? Do you see any problems with me installing this in stages? I was gonna run the lines long enough so I wouldn't have to do much except hook up a control system.
86 SWB 9.0 LITER
Old 06-16-2004, 04:54 PM   #4
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
I can't find any pics of mine, but the upper plate should conform to the outline of the spring pocket/crossmember. Clamp them down to it and drill the holes (have a good drill as they are double walled in places). I would run a straight fitting out of the front. I don't see a problem with doing it in stages.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 06-16-2004, 05:37 PM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
You know I have pics. See if these help you make sense of things. This shows the mounting plate attached to the spring pocket on top. On bottom you can see where the cup sets....
Old 06-16-2004, 05:39 PM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
This shows the mounting plate from another angle...
Old 06-16-2004, 05:41 PM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
One more for good measure....
Old 06-16-2004, 07:32 PM   #8
TIMSPEED
TIMSPEED's Avatar
Ken, can you get an above picture of those, to see exactly how the airline comes out the top? As I will be doing the exact same setup as AirMale here shortly.
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 06-16-2004, 08:44 PM   #9
N2TRUX
Happy to be here
N2TRUX's Avatar
I don't think I am going to have "exactly" what you want Tim. The reason being is once the bag is installed the fitting/air line is hidden in the spring pocket. You can put a 45 fitting on it and exit the line in what ever direction you prefer.
This is on my Blazer...
Old 06-16-2004, 11:50 PM   #10
TIMSPEED
TIMSPEED's Avatar
Aww ok, I gotcha Ken. Is that little red line your airline?
See Them Here
Old 06-16-2004, 11:55 PM   #11
N2TRUX
Happy to be here
N2TRUX's Avatar
Yep, that's it. Once you get under there you will see the best way to route it. On my 77 it comes out of the crossmember and runs down the frame. Just keep in mind chafing and heat do not mix well with air lines. Shield the lines from any source of heat and you will be just fine....
Old 06-17-2004, 12:18 AM   #12
BaggedC10
Under construction!
BaggedC10's Avatar
What size air line is that, Ken? 1/4"...???
My air line was routed the same way as Ken's w/ a 90* fiiting at the bag. Are you guys using plastic or brass fittings?
2001 Silverado bagged on 22's. *Sold*
BaggedC10 is offline   Reply With Quote
Old 06-17-2004, 06:45 PM   #13
AirMale
AirMale's Avatar
What are these gold anodized round plates for?
I thought I read on airlift's site that they are roll protectors. Do they have to be installed or not?
86 SWB 9.0 LITER
Old 12-12-2004, 09:13 PM   #14
love it loud
Calibration Engineer
love it loud's Avatar
bringin back a really old thread here.. what's the deal with these gold plates??
CANADIAN CONNECTION
love it loud is offline   Reply With Quote
Old 12-12-2004, 10:27 PM   #15
smokinn
smokinn's Avatar
OK silly question here. Is this for a better riding suspension? and can it be used on 4x4 or just lowered trucks?
Jason
smokinn is offline   Reply With Quote
Old 12-13-2004, 12:15 PM   #16
love it loud
anyone have any idea about the circular plates?
CANADIAN CONNECTION
