Old 08-22-2018, 06:31 PM   #126
Devil Pup
Devil Pup's Avatar
Re: Complete build change. Lifted 2wd
Well gettin her tore down slowly but surly. Really taking my time to be sure everything stays in order.
Old gaskets were pretty beat up but no obvious part of failure. hard to tell because how bad they were though.
Lifted 2wd 1969 C20/ 5.3LS/4L60E :http://67-72chevytrucks.com/vboard/s...d.php?t=728388
Devil Pup is offline   Reply With Quote
Old 11-26-2018, 07:56 PM   #127
Devil Pup
Devil Pup's Avatar
Havent updated this in a bit. Finally got the truck put back together and have been driving it pretty much every day for a month or so. I've put about 400 miles on it so far. I believe a sticky thermostat is what caused my gasket to fail in the first place since the temp was being a bit funny for the first couple miles of the new head gaskets. Swapped a new thermostat in and seems to be doing pretty well now.
I changed the lifter trays for new factory GM ones and upgraded to the MLS gaskets instead of the carbon ones. lots of cleaning to get all the carbon off the sealing surfaces but I got them to seal and used some new FelPro TTY bolts.
about 3,300 miles on it since the swap from bags to a lift and I'm loving it!
Old 11-25-2019, 12:33 AM   #128
kehstr
kehstr's Avatar
man, been away from the site for a little while now, and when I make it back the truck is done and running!!
After doing the head gasket has it run well with no further problems?
72 GMC highlander nicknamed by my then 6-year-old brother "stripes"
http://67-72chevytrucks.com/vboard/s....php?p=7378180
Check out my Youtube channel
@Chad's Fab
kehstr is offline   Reply With Quote
Old 11-25-2019, 02:02 AM   #129
Signkutter
Great job on this lifted c20. I was interested in lifting my C20...but I only wanted a 3 inch lift up front.
Signkutter is offline   Reply With Quote
Old 11-25-2019, 01:36 PM   #130
Devil Pup
Devil Pup's Avatar
Been good since. These LS motors are awesome. My blower motor went out for my AC/Heater but that's getting fixed soon. the truck itself is a blast to drive. I also got my cruise control hooked up which makes long drive really nice.
Old 11-25-2019, 01:37 PM   #131
Devil Pup
Devil Pup's Avatar
Thank you. The spindle lift is really effective but it puts it fairly tall. it clears a 33". I haven't lifted the back quite yet so it has a little rake.
Old 11-26-2019, 01:31 AM   #132
kehstr
kehstr's Avatar
I hear you! I feel the same way about my truck with a 5.3l. They run amazing with good power even stock!
@Chad's Fab
Old 01-23-2020, 03:14 PM   #133
Devil Pup
Devil Pup's Avatar
Took the Ol' girl out with the jeeps this weekend. 2wd, a locker and some good ground clearance got me around pretty easily. Found some snow, ice, mud, sand, and hard-packed.
Old 01-23-2020, 07:25 PM   #134
SCOTI
SCOTI's Avatar
Thought I replied to this thread back when you thought there wasn't much interest.... Apparently I never did. Outstanding job getting it done, sorted, & out being enjoyed.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-23-2020, 08:40 PM   #135
Devil Pup
Devil Pup's Avatar
Thank you. it really is fun to drive and is very reliable. did over 150 miles last weekend when we went off road and it didnt skip a beat.
Old 01-24-2020, 11:53 AM   #136
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Got to admit that when I saw the title of your thread I was like WTH? After going through it I really like your truck. Looks like a lot of fun. Good work.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 01-24-2020, 03:47 PM   #137
Devil Pup
Devil Pup's Avatar
Lol lifted 2wd aren't the norm. most people lower them so I get it. Thank you.
Old 04-24-2020, 04:00 PM   #138
doc70sub
doc70sub's Avatar
Great info & pics...looking to do my '70 C-10 Sub in the near future.
1970 Sub C-10 - 350/TH-350/3.73 12-bolt
Came home from the hospital in it & mine ever since.
1966 Catalina Ventura 2-door fastback 389/TH400
doc70sub is offline   Reply With Quote
Old 04-24-2020, 11:54 PM   #139
Signkutter
Wish there was a way to about a 3 inch lift in the front for my C20...Your truck looks great though
Old 06-16-2022, 11:26 AM   #140
NDM
Got a good amount of work done this weekend so figured id add a little update.
Bolted the crossmember in with some fresh Grade 8 Hardware.
The 73-87 frame i took the crossmember out of had these nice little reinforcement brackets for the crossmember that my 69 and previous 73-87 crossmember didn't have. They look to add a lot of strength so i used them on this frame considering that stress will be added with bigger tires.
ordered a bunch of parts from Rockauto. Shipping was vary fast but i ended up with someones used 88-98 ball joint. They actually fought me a little but took care of it and sent me a new one so no harm.
Installed the control arms, springs, spindles and rotors.
surprisingly had to jack the frame up more than it already was to fit the wheels on for a test fit. The wheel/tire set up is a 265-65-17 so i believe just under a 31.
At first glance i thought the tie rod was going to work with the stock sway bar but when turning i believe it will cause interference. So while i wait to get a reamer to change the tie rod to the top, i tarped the frame in anticipation of this weeks rain.
Dang! Figures that the exact info that I have been searching for would be lost in photobucket land.
Can you tell me what you used for this 2wd lifted swap. I am going to do my 2wd ls swap with a l96 6.0 liter and a 6l90e. That means I am saying goodbye to the front diff and 4wd. My goal is the same as yours. Smooth ride, wicked power and lifted for now.
The 4wd ls swap just has too much complication for me. I already did this exact swap in my 76 Buick so I am very familiar with how to do it. I just need to know how you did the 2wd lift.
Thanks and yes I realize that this is an old thread.
NDM is offline   Reply With Quote
Old 06-16-2022, 06:55 PM   #141
SCOTI
SCOTI's Avatar
The images might be missing but the info & parts used were mentioned within the build thread text.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-09-2023, 09:37 PM   #142
NDM
So I have acquired an entire front 1 ton crossmember from a 84 C20 from a local guy including the steering box. I will have to replace a bunch of the old stuff and get the conversion parts to 6 lug. I have some sand blasting to do and some painting.
My question to you is...Is there anything you regret or would do differently with this 2wd lift? I am about to purchase a 6.6 L8T with a 6l90E and am getting very excited! I am just kind of torn between lifted, stock height or lowered. This beast will be my daily driver when I am done. Should be so much better than the SRT Jeep that I got rid of to get this thing.
Anyways, Any regrets? Anything you'd do different?
Old 01-12-2024, 12:24 AM   #143
NDM
If you are still around the forum, Would you mind posting pics of the current fender to ground height for me? Last photo did not have the motor in yet and I could not find any other measurements. I am leaning toward doing the same swap as you did with the 88 up spindles but with my 6.6 liter L8t that I am about to swap.
Old 01-12-2024, 09:51 AM   #144
SCOTI
SCOTI's Avatar
His last activity on here was May of '23.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-05-2025, 01:30 PM   #145
Devil Pup
Devil Pup's Avatar
Sorry I went MIA. Life got busy so I have just been driving it, not working on it too much. Ill try to get you a measurement this week in case you still need it.
Also, to answer your above question, I would do some things differently. How it sits is great but I would have simply converted to 4x4 if I were to do it again. I will be doing that at some point in the future. Nothing wrong with the 2wd lift, I simply want it a bit bigger and more capable off-road.
Old 02-05-2025, 02:01 PM   #146
Devil Pup
Devil Pup's Avatar
Haven't done much but I did get a fuel door installed. Door is from the junkyard from a 88-98 Silverado. Still need to finish grind the welds, body work it and make a cover for the inside I had to cut out but it's nice to be able to put gas it it lol.
Name:  IMG_1491 (002).jpg
Cut the stock filler and used some exhaust tubing I had laying around to get the curves I needed. Welded the factory end of the stock filler onto it with a nice mounting tab so all the pressure wouldn't be on the bedside.
Name:  IMG_2757 (002).jpg
Had my little buddy weld it up air tight for me.
Name:  IMG_1667 (002).jpg
you cant see it in this pic but to make the fuel tank fit, I did have to notch the bed sill to sit down on the gas tank. the hose was between the sills so it didn't interfere thankfully. I notched and plated it so its still strong and now it fills without issue. Best mod to date I think.
Name:  IMG_6048 (002).jpg
Old 02-05-2025, 06:15 PM   #147
Devil Pup
Devil Pup's Avatar
Not the best pic but it sits right around 40-3/8" . . also as a note, i still have yet to put my rear lift blocks in, so I'd imagine this will come down another 1/2" or so once I do.
Name:  IMG_9049 (002).jpg
Old 02-06-2025, 10:19 AM   #148
SCOTI
SCOTI's Avatar
Attachment 2413182
Tire/wheel size up front still the same?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-06-2025, 01:29 PM   #149
Devil Pup
Devil Pup's Avatar
No. Original measurement I had rollers on it that had a 29 or 30"" tire if I remember correctly. Current set up is a 33" Mickey Thompson with some 17" Raceline wheels.
Old 08-18-2025, 05:06 PM   #150
Devil Pup
Devil Pup's Avatar
I picked up some original painted mirrors that my truck came stock with. I was set to mount the white ones and a set of stainless popped up so I swapped them out. . I can see a whole lot better then the "Sport mirrors" but I'm not so sure I'm sold on the look just yet.
Name:  IMG_1618 (002)1.jpg
Name:  IMG_1938 (002).jpg
2wd lift, 67-72 chevy, lifted, lifted 2wd, ls swap
